Fuse Panel and Converter addition.. 79 Scamp 16 - Fiberglass RV
Old 01-18-2015, 01:09 AM   #1
Trailer: Avion 30P and 1979 Scamp 16
I am going to add a fuse panel and converter to my 1979 Scamp 16.
Today it is only wired for 120V.
Can someone please tell me the best place in the trailer to locate these?
Thank You,
Dave
Dave Frazer is offline   Reply With Quote
Old 01-18-2015, 05:24 AM   #2
Joe MacDonald's Avatar
its really about convenince in my opinion. I would put it where it makes the majority of the wiring you have to do as easy as possible. if you already have 120 v power, then that might be an area to start, as the power cable already comes thru the hull, and you probably have a small breaker panel there. pick out what units you want to use, get their dimensions, and see where you can fit them
Joe
Old 01-18-2015, 06:36 AM   #3
Trailer: 2014 Escape 21
Virginia
On a 79 Scamp the power cord is more than likely on the door side. Most campgrounds now have the power and water on the drivers side and the newer Scamps have the power cords on the drivers side and the converter under the dinette seat.
Running a charge wire to the battery is easier on the drivers side of the trailer. Your old power cord outlet hole can usually be filled with a 20 amp ground fault outlet which real nice to have while camping.
Maybe not the easiest way to do it but it is more standard with the newer trailers. Also when moving the power cord I use a twist lock connector to get rid of the mouse entrance hole.
Eddie
Eddie Longest is online now   Reply With Quote
Old 01-18-2015, 07:13 AM   #4
Timber Wolf's Avatar
North Florida
Accessibility, both for the initial install and later service would be a priority to me. Short wire runs are a consideration but this would take a back seat to accessibility IMHO. In my 88' it is under the rear street side dinette and I expect to leave it there when I upgrade.
Old 01-18-2015, 08:50 AM   #5
You can replace everything in one unit with a Progressive Dynamics PD-4045, move your AC to the other side and get a fuse panel at the same time. I have installed about 8 of them and that's my choice. Most have been installed in the front of a dinette seat.
Old 01-18-2015, 09:55 AM   #6
Thanks guys!
Bob, my power cord is on the drivers side and comes in to the rear of the cook top under the counter. Do you use a twist lock when putting in a new power cord?
I guess this is so you don't have to push the cord back in the mouse hole for storage?
Dave
Old 01-18-2015, 09:58 AM   #7
Another question, with the Progressive Dynamics PD-4045 does this have the fuse panel and converter all in one unit?
Old 01-18-2015, 10:24 AM   #8
Yep, the PD-4045 has an AC input and distribution section with room for up to 8 AC circuits, a pigtailed fuse panel with about 12 DC circuits, a 45 amp converter and a multi-stage smart charger. All in one. Here is a typical link, also check the MFG's pages and, BTW, that's a fairly good price shown.
Progressive Dynamics Inteli-Power PD4045 45 Amp AC/DC Distributio..
Old 01-18-2015, 10:30 AM   #9
Shore Power
Originally Posted by Dave Frazer View Post
Thanks guys!
Dave
I always install a weatherproof 1`20 VAC input plug on RV's when rewiring. For smaller units a simple 3 pin 15-20 amp is sufficient, or you can use a larger 3 pin twist-lock which is a lot more secure when connected.
Unless there is an AC unit, or you have an "All Electric" trailer, the 15-20 amp connector is usually adequate for most 13' ers.
Old 01-18-2015, 05:02 PM   #10
When you say input you mean a recessed, flanged inlet device that has a male end in it?
I do have an A/C roof top unit. My trailer is a 1979 16ft.
I'm thinking a 20Amp flanged inlet twist lock. I guess I need to do some load calc's.
With the A/C/Heater and lights.....
Old 01-18-2015, 05:10 PM   #11
Bob- Is this what you install?
Old 01-18-2015, 06:09 PM   #12
If you have a rooftop air unit I would suggest always going with a 30 amp connection and cable. At many RV sites your power may be marginal and you can't afford any line loss between the power post and your rig.
Here is what a typical 30a twist lock input looks like, almost all others will cost less: 30 A RV Power Inlet - Marinco 301ELRV - Electrical Adapters - Camping World
BTW: The pic/link in your post #10 didn't work.
Old 01-19-2015, 11:08 AM   #13
North Florida
The PD-4045 looks like a good unit, but I don't see why one necessarily needs to re-do the 120V A/C side of things. My breaker box is fine and if it ain't broke I am not fixing it. I just want to upgrade the converter and 12V D/C charging, converter, and fuse/distribution side of things. Other PD products are better suited for that.
Old 01-19-2015, 11:42 AM   #14
Do what ever fits ones own needs.
I also wanted the additional ac breaker slots and to move the input cable anyway. . As I recall the 2002 Scamp we had was already wired for ac input to the power chassis, but I don't know how earlier units are wired. My Hunter came with room for exactly two breakers, main and outlets & a/c lights. Enough for 1973, but not for 2015.
The corollary to "It it ain't broken, don't fix it", is "If there's a better way, do it"....
BTW: It may still be less expensive and simpler to just buy a PD-4045 and not even wire in the a/c section, except for maybe a single breaker for the converter, from your existing AC box.
Fuse panel and 12 VDC wiring Eddie Longest Problem Solving | Owners Helping Owners 9 09-08-2012 05:53 PM
Scamp 16 - installing new fuse panel / 12v convertor John Carter Problem Solving | Owners Helping Owners 2 03-19-2012 11:49 AM
Need help with 12v fuse panel and wiring update Michael Collins Modifications, Alterations and Updates 15 03-27-2011 10:50 AM
Converter & Fuse Panel Nita F. Problem Solving | Owners Helping Owners 5 09-03-2006 06:44 AM
fuse panel Rick and Shannen Problem Solving | Owners Helping Owners 24 02-23-2006 11:55 AM
