Gap between door and trailer - Fiberglass RV
Old 05-31-2013, 07:02 PM   #1
Trailer: Currently shopping
Montana
The door on the Burro I just purchased has a sizable gap between the top of the door and the trailer. I can put my fingers through the gap - so it warped pretty good. The door alignment looks Ok so I dont think thats a problem. Currently there is no seal on the door so I will get that fixed. On the document center a gentleman provided an example of making kerf cuts on the inside of the door and bending the door back to make it fit better. Any other suggestions on how to fix this issue?
Thanks!
Bigsky1 is offline   Reply With Quote
Old 05-31-2013, 10:41 PM   #2
Myron Leski's Avatar
Trailer: 19' Escape
NM
Consider adding trim lok or similar around door edge. Available on EBay. Removing hinges and adjusting or realligning door to create a tighter fit may also work.
Myron Leski is offline   Reply With Quote
Old 06-01-2013, 05:15 AM   #3
Cory Hilby's Avatar
Trailer: Compact Jr 1972
Wait--I'll ask my brother Steve to look here & see if he want's to comment. He fixed Karen Langlois' Burro door, although her problem was that it was loose from rotting wood securing the hinges, so it hung crooked.
Cory Hilby is offline   Reply With Quote
Old 06-01-2013, 08:05 AM   #4
Steve Hilby's Avatar
Trailer: Compact Jr
Here, the first post in this thread is what I did with Karen's door. It seems to have worked well; at least I haven't heard otherwise!
Karen's Burro fix-up
The usual problem with Burro, etc, doors is that water gets into the inside of the door and the wood core rots, allowing the lower, curved, part of the door to sag, creating a big gap (and mismatch with the body) at the lower part. There have been plenty of fixes posted here, from kerf cuts and re-glassing, to threaded tension rods, to dismantling the door completely and fabricating a metal core.
Steve Hilby is offline   Reply With Quote
Old 06-01-2013, 08:31 PM   #5
Montana
I believe you have diagnosed my problem (re: water inside the door causing the sag. I appreciate all of the feed back folks have provided - thanks!
CT Windows, Gape at the Gap.... D Davis Problem Solving | Owners Helping Owners 20 03-16-2013 03:30 PM
13' Scamp screen door gap at the top? JohnF Problem Solving | Owners Helping Owners 9 09-27-2011 01:49 PM
Door gap Vicki A. Problem Solving | Owners Helping Owners 9 01-16-2010 06:43 PM
Boler 13' Top of Door Gap Emily R. Problem Solving | Owners Helping Owners 1 10-17-2009 12:12 PM
74 BOLER: I fixed the door gap. Jayson Wall Modifications, Alterations and Updates 3 05-18-2007 04:26 PM
