Gas fridge and towing problem - Fiberglass RV
Old 08-13-2006, 02:48 PM   #1
Steve Rosenberg's Avatar
I have a Dometic model RM 2410 fridge in my Scamp. When I first got it I could tow the Scamp with the gas fridge on and it would stay lit. Now when I tow my trailer the fridge turns off. Since it is so hot here in Northern CA when I get to where I'm going my fridge temp is way to hot.
Thanks;
Steve
Steve Rosenberg is offline   Reply With Quote
Old 08-13-2006, 03:56 PM   #2
Trailer: Burro 17 ft Widebody
Steve:
Going through a similar problem with a Dometic RM2333 three-way. 12v element on the road is quite inadequate, even though I have revamped the baffling to make it close to what Dometic requires. The changes helped, except that the air flow tends to blow out the flame when running on propane even more frequently than before. So, no propane use while on the road. I doubt that there is much I can do to keep the flame going reliably.
After changing the wiring for the 12v I have just about given up on that idea, besides the 12v element is only 125 watts versus 175 on AC.
I'm about to install a dedicated 400w inverter to run the frig on AC while on the road. The Odyssey has a 115 Amp alternator and I use two Group 31 batteries in the trailer. I may have to double check the wiring gauges from the alternator to the trailer batteries to determine if they are adequate.
I'm hoping that the AC operation will do the trick without causing undue electrical drain on the batteries. Arriving at a boondock site with depleted batteries is not going to work either.
Old 08-13-2006, 04:39 PM   #3
The down side of having a propane flame at the fridge when you tow is when filling up at a gas station.
Old 08-13-2006, 04:55 PM   #4
Trailer: U-Haul 13 ft
You can jump up a notch on the flame (thermocupler) or adjust it to high; should be a set-screw for this on the Dometic (I know the older models have one).
Lance M C is offline   Reply With Quote
Old 08-13-2006, 06:42 PM   #5
Administrator
Mary F's Avatar
Trailer: 2015 Escape 21; formerly Casita 1999 17 ft Liberty Deluxe
My dad always used to stop a block ahead of the gas station and shut off the fridge. I don't think it's something that's easy to forget.
But, you're right; he'd also have to stop again after leaving the gas station and relight it. That's three stops instead of just the one it would take if you (he) could run the fridge on 12 volt. However, his fridge didn't have a 12 volt option, so he saw propane as the only way to go. On the road.
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 08-13-2006, 09:26 PM   #6
I run my fridge with a 400 watt inverter while under way....I have one trailer battery and haven`t had any problems.......just remember to switch over to propane if you are going to park for about an hour or more.....Benny
Old 08-14-2006, 06:29 PM   #7
CharlynnT's Avatar
Trailer: Boler 17 ft
Our 3-way fridge will not work on propane unless the Boler is completely level.
Before we head out, we have it on electric to get it nice n cold, then once on the road with 12 volt we have a few freezer packs in there for travelling.
In fact, whenever it's not on "shore power" I treat it (almost) like an ice box: rotating freezer packs from freezer to fridge and back.
CharlynnT is offline   Reply With Quote
Old 08-14-2006, 07:27 PM   #8
Trailer: 1981 13 ft Scamp ('Dacha' Russian summer house) / 2006 Tacoma V6
My fridge used to blow out a lot but I put in an air baffle in the grills. Now the problem is feeble cooling. But it's been really hot. I'm going to pull it out and try the rotation routine in case there is a bubble in the ammonia line. If that fails, then into the dump. I've had more than one trip ruined by the crappy gas friges that need to be babied-blow outs ,need to be leveled, air circulated inside and outside and too small for two people.
I have a Dometic portatable ($360) that I keep in the truck that that is brand new that works well, so maybe my 1981 trailer unit is ready for the grave. Maybe Dometic has improved, but gas friges are a real pain in the ass! They kill your battery on 12V and are weak if the temp is over 90.
They are like computer printers-the greatest source of all complaints.
jim munson is offline   Reply With Quote
Old 08-29-2006, 02:03 PM   #9
Trailer: Cadet
What is the make and model of your fridge?
Jeremy G is offline   Reply With Quote
Old 08-29-2006, 03:57 PM   #10
Trailer: 84 16 ft Scamp
I have a Norcold in the Avion that I parked on a hill at a relative's house and forgot to turn off the gas. It didn't work at all after that. So I checked with a local RV place and they assured me it could be repaired for about half the price of a new one (or less if I would remove the coolant apparatus myself). I did that and it wasn't much of a chore and had it sent to a rebuilder in Everett, WA.
After it came back all looking like new, I reinstalled it and it worked much better than it ever had. Before on warm days it became . . . well, warm. It never would hold ice cream. But after the rebuild it works great, perhaps better than new.
I don't know if some kind of magic could be worked on your Dometic like they did on my Norcold, but I sure was satisfied with the outcome.
fridge, propane
Fridge Element Problem Nancy and Don Ostaff Problem Solving | Owners Helping Owners 4 07-24-2009 08:17 AM
Dometic Fridge Problem! Michael Pupeza Problem Solving | Owners Helping Owners 0 05-20-2008 07:06 PM
New Trailer Fridge Problem? Ed Harris Problem Solving | Owners Helping Owners 0 11-11-2007 06:51 AM
fridge problem Legacy Posts Problem Solving | Owners Helping Owners 12 07-05-2003 02:57 PM
Towing Problem Legacy Posts Problem Solving | Owners Helping Owners 24 02-27-2003 07:21 PM
