Gas mileage and air deflectors for vans - Fiberglass RV
View Poll Results: Will a deflector make much difference?
Yes, it will help 0 0%
Yes, it might help, but not much. 0 0%
No, I tried it and it was not worth the cost or effort 0 0%
Yes, but your driving habits are more important than the deflector. 2 100.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Old 08-30-2019, 09:19 PM   #1
Trailer: currently shopping
Ohio
I tow my 14' camper with a 2000 Dodge Grand Caravan. I am considering attaching a panel set at a 40 degree angle to the roof of my van at the back to deflect air over my camper, which is about 2-3 feet higher than my van roof. Will this improve my gas mileage, and is it worth the effort? I have the materials to make something with a deflector panel about 4 feet wide and about 20 inches tall. This would attach to the stock roof rack.
nor1492 is offline   Reply With Quote
Old 08-30-2019, 09:30 PM   #2
I think you need access to a wind tunnel to work out all the parameters. Without information, you may make things better or worse. Maybe you would improve gas mileage and destroy handling.
Old 08-30-2019, 11:01 PM   #3
Raspy's Avatar
Trailer: Black Series HQ19 on order
Smith Valley, Nevada
Just a guess, as without a wind tunnel it seems impossible to say, but that sounds like a lot of download on the panel and the rack, a lot of buffeting sound in the van, and a lot of turbulence between the van and the trailer. All of that sounds like worse mileage and some work to achieve it.
One advantage though, with all the buffeting sound inside the van, if the panel gets torn off by wind resistance, you'll know it right away by the quiet.
Seriously though, how much improvement are you expecting? Even if it seems to work, I'd bet it's not measurable. And the only time it might be is at highway speed. Why not just slow down 5 MPH and get a much larger benefit? Then you won't have to build the rack and you won't have to push on the throttle so hard.
Old 08-30-2019, 11:42 PM   #4
The poll at the top has three "Yes" options and one "No" option.
Another pointless poll.
Old 08-31-2019, 03:01 AM   #5
Trailer: 2017 19' Escape
Everywhere
If it's the right shape/design, it should get you a small-but-not-zero improvement in gas mileage. The wrong shape could easily tip it over to worse, though. It's pretty hard to guess/generalize whether it'll help or not. Realistically, the only way to find out is to test it. I'd be surprised if it made as much of a difference as driving smoothly and slowly, though.
Also, keep in mind that any wind resistance improvement is also going to mean a bit more braking required on steep downgrades.
Old 08-31-2019, 06:48 AM   #6
Trailer: 2014 Escape 21, Lil Joe
I have used a wind deflector on my truck roof with several trailers. My deflector is only about 16" tall. It does not need to be as high as your trailer. It just kicks up the air flow over the trailer. My deflector is adjustable. I adjust it so very few bugs hit the front of the trailer. My assessment is it does not help gas mileage that much but it keeps the majority of bugs off the front of your trailer. That can be a good thing during love bug season in Fl.
Eddie
Eddie Longest is online now   Reply With Quote
Old 09-01-2019, 05:36 AM   #7
Gilles's Avatar
Trailer: Bigfoot 25B21RB, 2004
Quebec
We have already used an adjustable baffle on our Dodge Caravan in about 2005, with a trailer Trillium Jubilee 1980.
Without the deflector when our speed reached 90 km / hr (55 mph) and more we felt a movement back and forth in the caravan.
I found and installed an adjustable baffle.
After several tries I had to install the baffle the furthest possible rear of the caravan, to make completely disappear the unpleasant movement felt.
For adjustment in degrees, each vehicle and trailer is different.
On the Internet I had read that to know if we had the right angle, we would stick a ribbon in the top of the deflector and the ribbon should float horizontally when we reached the desired speed. Not easy to check ...
The other method suggested by my parts supplier is to randomly adjust the deflector, until the movement disappears and as Eddie wrote, that the insects had dimunied much on the top of the trailer. It's this method that worked for us.
When I replaced the Caravan with a Dodge Journey, without a deflector I did not feel the movement of back and forth felt with the Caravan. So not installed.
I have never calculated to measure the difference in gas with or without a deflector.
Each vehicle and trailer will react differently, in my experience.
Gilles
Bigfoot 25B21RB.
Towed with Dodge RAM 1500 Echo-Diesel, 3.0 L., 8 speeds.
Old 09-01-2019, 10:33 AM   #8
The commercial truckers have vortex generators available and measured improvements after much "testing" average the max improvement of about 1 - 3 %.
The idea is to generate vortexes that leave the rear of the TV and help the air bypass the area between is and the trailer.
They also install them at the rear of the trailer to smooth out the airflow behind it.
All in all for our small trailers I wonder if it is worth bothering with.
redbarron55 is online now   Reply With Quote
Old 09-01-2019, 10:48 AM   #9
Maybe if your tug burned 4-5 times as much fuel and you towed your trailer as many miles as a commercial semi-truck does (roughly 45,000 on average)... but most of us only put 1,000 to 2,000 on each year on our trailer (and truly this time.. YMMV! )
Old 09-01-2019, 03:29 PM   #10
Gilles's Avatar
Quebec
On my Dodge Caravan, I had installed the deflector only to remove the discomfort of turbulence at 55 mph and more, not for fuel economy, I never calculated it.
Gilles
Bigfoot 25B21RB.
Old 09-01-2019, 07:37 PM   #11
ibupnorth's Avatar
Trailer: 2018 Casita SD 17'
You didn't mention what trailer you have so it's hard to imagine its shape. I would think something shaped like an Airstream or a Scamp with a wall installed AC would be very difficult to easily improve upon a van's mpg.
IBUPNORTH
ibupnorth is offline   Reply With Quote
Old 09-01-2019, 07:42 PM   #12
You don't say who you are responding to so it's anybody's guess. However, if you look at the profile under the poster's name, you might find info about trailer and tow. Or not.
Old 09-01-2019, 08:03 PM   #13
ibupnorth's Avatar
Did you look at the originator's profile? There's no trailer type noted.
IBUPNORTH
Old 09-01-2019, 09:05 PM   #14
I still don't know who the OP is. Who are you referring to? Which post?
Wind deflectors? Shawn B. Towing, Hitching, Axles and Running Gear 37 08-22-2017 07:17 AM
Sterling rv/Great West Vans Balou General Chat 3 09-01-2015 03:33 PM
Air Deflectors for Solar Panels tractors1 Modifications, Alterations and Updates 18 07-17-2015 06:21 AM
Sprinter Vans 2yax2go Towing, Hitching, Axles and Running Gear 41 01-28-2011 06:47 PM
Wind Deflectors Roger C H Modifications, Alterations and Updates 1 06-14-2009 04:57 PM
