Gasket around door opening. - Fiberglass RV
Old 04-15-2017, 08:26 AM   #1
Trailer: In the market
Illinois
I am still having a problem finding gasket material that fits my 1979 1300 Trillium. Here is the issue. The top half of the lip edge is around a 1/4" thick.....however, the lower half expands to 1/2"+ thickness of the lip edge. I have found gasket material that fits top half.....but not lower. Need help. Thank you.
donksax is offline   Reply With Quote
Old 04-15-2017, 11:15 AM   #2
Kai in Seattle's Avatar
Hi, Michael,
Is this self-stick gasketing? Have you considered using the material that fits around the top half, and doubling up around the lower half? Close-up photos could help.
We reglued our old gasketing on our 1973 amerigo...but sooner or later want to replace it, some auto parts stores carry gasketing, so do camping world type stores...but we haven't found quite what we want yet. Maybe it's not as crucial as we think to find the exact same type of gasketing...we'll have to face that when we get to it.
Hoping your project comes out great!
BEST
Kai
Semper ubi sub ubi.
Old 04-15-2017, 11:34 AM   #3
Trailer: 1976 Trillium 1300
New Brunswick
Hi I too have a Trillium and I found a "D" shaped hollow gasket on e-bay. I put it on my trailer and have had no leaks or gaps around the door! Just google the above description and you should find the listing. I used the 5/8" size gasket. It compresses to accomodate the width of the gaps! Good luck with your fix. Do make sure you clean the surface well and place the strip carefully as once it sticks it's hard to shift again ! Duane
getaway1 is offline   Reply With Quote
trillium
rubber gasket molding around door frame donksax Problem Solving | Owners Helping Owners 6 01-06-2017 09:36 AM
Replacing the Gasket around the door of my Perris Pacer 1985 plant_sandwich Problem Solving | Owners Helping Owners 8 10-17-2016 04:23 PM
burro door repair and door gasket fred wark Care and Feeding of Molded Fiberglass Trailers 3 11-29-2015 06:25 AM
opening door window cpaharley2008 Modifications, Alterations and Updates 3 07-04-2011 04:18 PM
