Old 02-13-2011, 01:41 PM   #1
Borden's Avatar
Name: Borden and Carole
Gasket for lights
Hi: need to seal lights in a way that water is out and possible to change the bulb at a trucks top.
The old lights had silicone and very hard to remove chipped one.
Purchased two new reflect-o-light 110-150 lenses
Still have gasket problems but now will be able to change bulb.
1 got Cork Rubber gasket sheet at Canadian Tire
2 cut with scissors and exacto layers to fit
3 now glue layers
4 upgrade to stainless screws
5 will use leather punch for 3 holes at screws
Considering two sided tape to connect layers has anyone done this?
1978 Ontario made Boler
Old 02-13-2011, 03:23 PM   #2
Trailer: 1995 Scamp 16' Deluxe
Smile tail lights
Have you read this?
Making Bases for Reflect-o-lite 110 150 Tails in Repair and rebuild tips and ideas Forum
3 now glue layers
fwickeham is offline   Reply With Quote
Old 02-13-2011, 03:35 PM   #3
Borden's Avatar
fwickeham will read it thanks
Old 02-13-2011, 04:04 PM   #4
I would have used Butyl.
Double Yolk
1988 16' Scamp Deluxe
Old 02-13-2011, 07:10 PM   #5
Borden's Avatar
fwickeham reading aside will go with the rubberized cork gasket the link is with custom made base and they had more room to fill. I have the original bases and the outer lens flange goes over the edge of original base. The link would be good for anyone making a new base. If making a new base was needed would probably use Bargman No.99 Lens Reproduction as it looks similar and can be more readily replaced if broken.
Butyl to join the cork sections may work Donna D. Doing so would require it be used sparingly. Worry about seepage.
Inside pieces top left picture fills recessed depth and one ring over top fits just right. After test fit and worry about having a problem getting in for bulb changes if to much is used; will just punch screw holes in outer ring and screw the lenses on.
Thanks for your input though.
lights
Window gasket clarification Amy M Care and Feeding of Molded Fiberglass Trailers 17 08-28-2012 03:35 AM
black gasket stuff.... marjie s. Problem Solving -- Owners Helping Owners 1 05-25-2009 04:26 PM
window gasket marjie s. Problem Solving -- Owners Helping Owners 6 04-23-2009 05:10 AM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 10:54 PM
Window gasket Legacy Posts Problem Solving -- Owners Helping Owners 9 05-25-2003 07:40 PM
» Trailer Showcase
Lil Egg
Ranger
Bigfoot
Mike N.
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
