Gel Coat Chips - Fiberglass RV
Old 08-13-2012, 09:43 PM   #1
barryra's Avatar
Trailer: 1993 13 ft Scamp
Gel Coat Chips
I am cleaning the Scamp with Bar keepers before I apply the floor sealer to make it shine. I see there are some rock chips in the front & a few places where some 1/4 inch sized places have the gel coat missing.. like little divets.
Is there something I can apply that would fill in these spots?
The place where it looks like rock chips seems like it's raized & could be scrubbed off but it wouldn't come out so I am thinking its chips.
Thanks for any info!
barryra is offline   Reply With Quote
Old 08-13-2012, 11:42 PM   #2
Trailer: 2008 13' Scamp
Chips that are larger than what you seem to be describing can be filled with gel coat, wet sanded and polished to make an invisible repair. Gel coat for repairs is usually available in small jars at stores selling figerglass supplies.
I sounds like your damage may be less than what would require filling with gel coat. Gel coat thickness varies. It is often possible to carefully use wet and dry sandpaper to take out small imperfections. For things like that I use, depending on the amount of damage, 400/600/1000 grit wet and dry sandpaper, then buff and polish.
Ron
Old 08-14-2012, 07:14 AM   #3
Trailer: 1974 Trillium 1300
Gel coat chips on my Trill were at the front and pretty bad. No amount of salsa was going to fix those! So I masked of a curve and sprayed Beige undercoating over it all to protect and hide. 2 cans did it but I was a newbie so I did not do a perfect spray job. Got a few spots where I did not move the can enough. 2 coats or more was needed. Looks better and is protected. Time will tell if the stones penetrate.
Do not remove the tape until dry and even then slowly, pulling away from the fresh edge of goo!
indigodave is offline   Reply With Quote
Gel Coat Touch up Greg G. Care and Feeding of Molded Fiberglass Trailers 1 05-17-2010 04:48 PM
Bigfoot gel coat Ralph W Problem Solving | Owners Helping Owners 4 05-05-2009 01:30 PM
Gel coat protection GeorgeR Care and Feeding of Molded Fiberglass Trailers 18 03-20-2008 10:59 PM
Gel Coat Restoration Paul Wood Modifications, Alterations and Updates 11 10-07-2006 04:34 PM
Gel coat troubleshooting Legacy Posts Care and Feeding of Molded Fiberglass Trailers 1 01-20-2003 06:05 PM
