Gelcoat damage - Fiberglass RV
Old 09-11-2018, 06:33 PM   #1
Gelcoat damage
We have a 2010 Casita. I washed it yesterday in preparation for our annual fall trip. In the process, I found a 2" gouge in the gelcoat in the front of the camper.
I don't have time to get it fixed, but I know we are heading into a raining fall trip. Should I try to seal it with something?
And, should I take it to a fiberglass shop (e.g., boat shop) to get it fixed?
SHIBSHI is offline   Reply With Quote
Old 09-11-2018, 07:38 PM   #2
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
Shibshi, if the gouge is deep (through the gelcoat layer into the fiberglass layer) I would recommend patching it with a marine epoxy putty product such as Marine Tex prior to travel. This would protect the fiberglass layer. If the gouge is not entirely through the gelcoat layer, then no repair is needed prior to travel.
Later on, you could have a fiberglass/marine repair shop repair the damage if you desire a more "cosmetically appealing" result. In the process, the shop would probably grind away the epoxy putty repair.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
Old 09-11-2018, 07:45 PM   #3
gelcoat repairs
For general information on repairing fiberglass, you could check this link:
SOLD - Totally Restored 13' Scamp for sale
Basically, restoring gelcoat to its original look is difficult, and if hired out, it is expensive. The linked thread discusses various solutions.
Old 09-11-2018, 10:09 PM   #4
John in Santa Cruz's Avatar
Trailer: 2014 Escape 21, 2002 Ford F250 7.3 Diesel 4x4
presumably you mean 2" long not 2" deep.
you can get a gelcoat repair kit at most any marine store, and find all sorts of howto's. basically you dremel out the edges of the gouge so they are smooth, then mix a 2-part epoxy filler, smear that on with a plastic spreader, let cure, wet sand with 800, 1000 til smooth, then paint with white gelcoat, wet sand with 1000, 1500, rubbing compound, then polish and wax.
Old 09-12-2018, 12:59 AM   #5
Borrego Dave's Avatar
Trailer: Casita SD17 2006
You shouldn't get any water intrusion from a scrape in the gel coat. If it makes you feel better for the time being, you could put some tape over it.
Old 09-12-2018, 06:27 AM   #6
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
I would have Scamp send you some of the same gelcoat that they use so you easily get a colour match. Add a bit of catalyst to it, and apply after prepping the area. There are lots of great videos out there to help you through the process. There are a bunch of steps to the sanding and fairing, but none of them very tough at all.
How do I know you say? Well, I did a major boo-boo.
I taped off the area removed all the loose stuff and opened small cracks to better accept the repair.
I applied the gelcoat. I got a bottle of it from Escape so the match is perfect.
Then sanded it all smooth with various gradations of paper.
I just did this about 7 weeks ago. I still need to do the final buff, but there are a couple wee voids in the finish I might touch up first, but nobody would see them unless I pointed them out.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 09-12-2018, 08:05 AM   #7
David Tilston's Avatar
I am sensing that there is a story here.
Old 09-12-2018, 08:11 AM   #8
Yeah, that!
Mid winter I was backing my cargo trailer into my drive beside my 5.0TA . I had to angle across the front of my Escape in order to cut in around a tree. While it was looking pretty good out my mirrors I came to hard stop. Well the truck was right at the curb where there was a huge pile of ice on the road and I just assumed I was stuck on that. I put it in 4-wheel drive and booted it and it still didn't move. I then looked up high in my passenger mirror and saw both the back end of my cargo trailer and the front end of my Escape lifting up in the air. The corner of the cargo trailer bit into the fiberglass giving it a good hold seems. Anyway, despite my aggressive ramming of my trailer the damage really was not all that bad.
With gelcoat being a resin and not a paint, it added a bit of strength and rigidity to the repair.
2017 Escape 5.0 TA
Old 09-12-2018, 11:19 AM   #9
Good thing it was fiberglass and gel-coat and not an aluminium Airstream.
Old 09-22-2018, 03:56 PM   #10
Sin in haste ; repent at leasure. Once water gets into the fiberglass laminate through damaged gelcoat it wickes its way into the structure which reduces its strength. This cannot be repaired without replacing the affected section.
Stephen_Albers is offline   Reply With Quote
Old 09-22-2018, 05:36 PM   #11
Wow. That looks great!
Old 09-22-2018, 06:06 PM   #12
While repair should be done as soon as possible it is not because water would wick into the fibreglass, as being a waterproof substrate it would not do so. Sunlight directly on the exposed fibreglass is damaging, especially on the fibres as time passes will cause it to bread down. Sunlight even affects gelcoat, which is a resin much like what is used in the fibreglass layer of our trailers, and this is why protecting with a good wax with UV protection will help it stay in good shape for much longer.
2017 Escape 5.0 TA
Longing to spray a new gelcoat Gigi Modifications, Alterations and Updates 14 05-06-2006 08:17 AM
Gelcoat Rejuvinator Applications...any good? Bob H Care and Feeding of Molded Fiberglass Trailers 23 04-15-2006 07:25 AM
Repairing the gelcoat Legacy Posts Care and Feeding of Molded Fiberglass Trailers 16 08-07-2003 02:56 PM
Fiberglass, gelcoat or paint? How can I tell? Legacy Posts Problem Solving | Owners Helping Owners 2 07-12-2003 01:26 PM
Renewing gelcoat surface Legacy Posts Problem Solving | Owners Helping Owners 5 06-18-2003 01:59 PM
