Generator problem: Overload light - Fiberglass RV
Old 06-18-2008, 07:12 PM   #1
Trailer: aerolite
Generator problem
Two years ago I purchased a McCulloch 2000 tc generator. It has worked fine until a bearing in the furnace of my RV went out and the generators overload light went on and stays on, also the amount of power has diminished. I have called around to see if it is fixable but no one wants to touch it because they say the company is out of business and they cant get parts for it. Would like to know if there is anything that can be done to repair?
Dale
Dale Peters is offline   Reply With Quote
Old 06-19-2008, 04:44 PM   #2
Pete Dumbleton's Avatar
IIRC, some McCullough models were rebadged Kipors -- You might look for a Kipor repair place.
Old 06-19-2008, 07:04 PM   #3
Gina D.'s Avatar
West Coast USA
yep, that one is a rebadged Kipor.
Kipors service network is growing by leaps and bounds. A google search should find a service center near you in Colorado.
Old 06-19-2008, 11:39 PM   #4
When my overload light goes on I have to shut the unit down and restart and the light remains off.
Is it possible that you have your switch that allows the unit to run slower when not much power is needed is in the wrong position.
I assume that you are running on the AC Voltage side of the unit and if so, test to see if you can run on the 12Volt DC side to supply the voltage to your battery as the furnace more than likely runs on 12VDC.
generator
Porch Light Problem Perry Mac Donald Problem Solving | Owners Helping Owners 9 07-07-2010 05:27 PM
Trillium brake light problem -- help! Gary Seronik Problem Solving | Owners Helping Owners 11 06-12-2008 08:45 PM
Circuit Breaker overload? TorreyT Problem Solving | Owners Helping Owners 10 05-20-2007 02:33 PM
12V LIGHT PROBLEM - FIXED!!!!! Christi W Problem Solving | Owners Helping Owners 12 02-28-2007 11:42 PM
Trillium brake light problem -- help! Gary Seronik Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
