Georgia reno of 2001 Scamp - Fiberglass RV
Old 05-04-2013, 04:34 PM   #1
Trailer: 2001 16' Scamp
I have posted on other threads, but since it is apparent my 2001 Scamp will need more than a good clean and some new cushions. I thought I would start a new thread to post pictures and ask questions as I go.
It has been raining in Georgia since I picked up my Scamp. Thankfully it is dry in my husbands barn.
Today, I cleaned the shower and water came pouring out onto the floor. It looks like a cap or something is missing. It has a huge grey tank and I can see pipe running from the shower to it, so not sure what is missing.
Second, the air conditioner (Coleman Mini-mach) doesn't work at all. Since it is much needed here, what would you guys recommend I replace it with??
Thanks for the help! Pictures soon.
Susan H.
volunteergal63 is offline   Reply With Quote
Old 05-04-2013, 04:49 PM   #2
Also, the acorn nuts in the shower are rusted!! What should I replace them with so they don't rust again. I already have to replace several rivets, so that part isn't a problem. Just don't know why they would put something in a shower that rusts.
Old 05-04-2013, 05:01 PM   #3
Steve Hammel's Avatar
Trailer: Trillium 4500
By floor I'm assuming you mean the barn floor under the Scamp? Is the blade valve closed for the grey water tank? Also the shower drains to the grey water tank by what looks like a garden hose. Make sure that is connected.
Old 05-04-2013, 05:02 PM   #4
The acorn nuts are not replaceable unless you cut off the rivets that they attach to. Surprise surprise they are not threaded to anything. I found out when I wanted to change mine.
Old 05-04-2013, 05:29 PM   #5
Rusted acorn nuts, ugly... how about some paint? Like a rustbuster kind. I'd recommend POR-15, but that would be ridiculous for a couple of bits of rust. Maybe a Rustoleum product and a small paint brush?
Old 05-04-2013, 05:45 PM   #6
Air conditioner may be fixable. Start out by checking if it has power to it. May be some corroded connections. I had that problem with an A/C unit that was on my daughters popup.
Old 05-04-2013, 06:27 PM   #7
Ed Harris's Avatar
Which 16' layout do you have?
On certain layouts the grey water is pumped to the tank and not gravity feed so that may have a bearing on whats happening?
Also before buying a new AC or anything else for that matter try dragging this trailer to a reputable RV place and letting them look it over,might save a lot of time and money?
Old 05-04-2013, 06:54 PM   #8
I second the AC thing. They don't usually just go out. Eventually they don't cool as well but that can be fixed with a recharge. If nothing is happening check fuses, etc.
Old 05-04-2013, 07:07 PM   #9
Something seems to be missing? There is a pump.
Old 05-04-2013, 07:09 PM   #10
I was going to replace the rivet and acorn nut, just wanted to know if anyone knew a rust proof alternative.
Old 05-04-2013, 07:17 PM   #11
Stainless steel acorn nuts. Very expensive though.
Old 05-04-2013, 07:19 PM   #12
Attachment 58640
The black ring with the white 'pipe' in the middle is the shower drain.
Old 05-04-2013, 07:20 PM   #13
Attachment 58640
I believe that is the aforementioned waste water pump. I've never seen one before. The other thing is the black water/toilet outlet. It doesn't appear to have it's cap but I hope that is not your problem.
Is there a line that runs from the pump back to the grey water tank?
Old 05-04-2013, 07:22 PM   #14
Where can you get stainless steel acorn nuts??
Old 05-04-2013, 07:25 PM   #15
Any hardware store should carry them. I bought some and they were over $1 each.
Old 05-04-2013, 07:27 PM   #16
The black water tank has a separate drain from what I can see. It is full of water and cleaner at the moment,no leaks. will drain it in the morning. The water from the shower came straight out of the small white pipe onto the barn floor. The pipe to the grey tank comes out of the white fitting ???
Old 05-04-2013, 07:36 PM   #17
Weird, not something I've seen before. Does the blackwater come out of the black part? If so that would be cool as the white pipe would drain right into the sewer line when hooked up. Other than cleaning the shower you probably won't have water in it unless hooked up.
Old 05-04-2013, 07:40 PM   #18
The air conditioner is 12 years old and even if I can fix it for now. I don't want it to go out on me while I on the road. How long do they usually last. Mine is a Coleman Mini-Mach.
Old 05-04-2013, 07:43 PM   #19
Mines an 84 and still going strong.
Old 05-04-2013, 07:49 PM   #20
The black water has it's own pipe with a valve and drain.
The black water does not come out of the black fitting. The only thing hooked up to it is the pipe going to the grey water tank and the pump.
The white pipe looks jagged as if something broke off. There is nothing to connect to it.
Weird to me too.
Susan H.
NV | 2005 13' Scamp w/AC in Reno, Nevada $7,000 OBO-sold Crystal B Classified Archives 12 03-17-2013 05:51 PM
2001 Scamp 16' Thomas G. Referrals: Molded Fiberglass Trailers 0 01-14-2013 06:53 PM
WI-2001 16' Scamp Tony Nowak Referrals: Molded Fiberglass Trailers 0 01-09-2013 09:47 AM
GA | 2001 Casita 17' SD - Georgia - $9500.00-sold- TomP Classified Archives 1 09-16-2012 12:48 PM
1998 13' Scamp for Sale in Georgia Rosemary Classified Archives 4 08-23-2009 06:22 PM
