Getting behind the sink in an 83' Bigfoot 17ft - Fiberglass RV
Old 05-06-2019, 11:55 AM   #1
Trailer: In the market
Hello! I popped a fitting on one of my lines near the taps in the back of the sink due to some early spring camping and freezing in the lines. Ive been struggling with trying to get behind the sink. I've pulled the drawers out and it still seems to be very difficult to get at. there is a vent on the outside that is above the fridge and slightly to the side of the sink I want to try but its sealed and would rather not tamper with it unless I know it'll help. I am in a bush camp so the fix isn't urgent but would definitely like to do it soon! Thank you
Ianp995 is offline   Reply With Quote
Old 05-06-2019, 01:23 PM   #2
I had a similar access problem(different brand trailer) and found the best way was to pull the sink out. After that I had great access.
Old 05-09-2019, 06:36 PM   #3
Trailer: Bigfoot 17
I have a 1986 BF 17. I removed the stove to get at plumbing under the sink. Remove top plate(snaps off) allowing access to gas disconnect. (Turn off propane) Then undo screws holding unit in place on sides when you open oven door. Then gently slide it forward being careful of gas pipe. I have done this several times with no issues.
Good luck!!
Ralph5555 is offline   Reply With Quote
Old 05-10-2019, 02:26 AM   #4
Trailer: Boler 13 ft
Being a plumber for many years, I would say removing the sink would be the best way to get to the plumbing connections.
bigfoot
Drilling holes behind burro sink MaryVS General Chat 6 04-02-2018 08:27 AM
towing boat behind bigfoot fith wheel? RichardP Towing, Hitching, Axles and Running Gear 6 03-09-2014 10:12 AM
Comparing 17ft Bigfoot to 17ft Casita LD Swasson General Chat 41 03-20-2013 11:00 PM
fishing wires behind Scamp's ceiling carpet Legacy Posts Electrical | Charging, Systems, Solar and Generators 6 07-11-2003 10:18 AM
