Getting ready for the road - Page 3 - Fiberglass RV
Old 11-04-2012, 06:42 PM   #29
Trailer: Bigfoot 1981 Trailer
Great thread. I am getting all sorts of ideas just from these postings. First off, PD4045 seems like a great idea, as others have sugested, as I am putting one in this week, as it is an all in one unit, with no distribution panel needed, and pigtails with numbers on them so the installation should be easy. There are 2 30 amp DC fuses, and 10 20 amp fuses so lots of available power.
As far as putting in a 12 v cigar receptacle, I would suggest putting in heavy wire, say 12 or 10 gauge rather than 16 gauge so your inverter does not turn off when plugged in with heavy loads.
For heating, a catalytic heater (pro cam is one of the lowest price) but there are other ceramic and blue flame models available (Vanguard, etc) and it does not require any power to operate. Of course it is not legal in Canada, but I have had them installed in the States and it does give out a lot of heat, and a thermostat is very helpful.
LED lights save on power, and I am still looking for some fixtures with about 300 lumen for reading. Still doing some research.
Old 11-04-2012, 06:49 PM   #30
Trailer: 1973 Love Bug '13
Jim,
Keep us posted as you do your project. I would love to get your input as you work through it.
Cathy
Cat futrell is offline   Reply With Quote
Old 11-04-2012, 07:49 PM   #31
honda03842's Avatar
Name: Norm and Ginny
Well Electrified
We have modified our Scamp to include 10 AC outlets, and 3 DC outlets.
The AC outlets are primarily located for convenience, literally all over the place. It's not that we use a lot of AC but like to have it where we need it. We increased the number of breakers from 2 to 4 to accomodate the additional outlets.
We primarily use the DC outlets for small 100 watt inverters for running things like the TV or Sat dish. One 100 watt inverter easily drives our TV and Sat dish.
We mostly use the 100 watt inverter when dry camping. We also have a 1200 watt Inverter that allows us to have AC throughout the trailer if we choose. I will say we rarely use the large Inverter.
As to lighting we have replaced everything except the Scamp Florescent
with LEDs. I believe the standard incandescent lamps produce about 120 lumens of decidedly yellow light. We have replaced ours with white LEDs of about the same lumen output.
Besides lower current draw, the LEDs are more tolerant of lower battery voltage, generally not changing light output much as the battery drops. Some people do not like the bright white LEDs, primarily, I think, because they are use to yellow lights. For us we find the white light provides higher contrast when reading.
We do have solar panels taped to our roof, 80 watts. In general they have been adequate to meet our power needs, not enought to run our electric hot water heater or electric heater but for virtually everything else, lighting, TV, Sat dish, charging phones, computers, e-books, running the water pump....
We have three ways to charge our battery, from our converter, from our solar panels and from our Honda's generator while driving. We tend to only use the Honda's generator if we're driving on a particulalry cloudy day, this is activared b a switch on the Honda's dash.
We no longer carry a seperate generator but do own a very small 1000 watt generator that we bought pre solar panels for a trip to Labrador. It was more than capable of running the trailer.
We also carry a 100 watt cigarette lighter inverter in the car that we use for charging our cell phones or on occasion our computer while driving.
We were gone for 315 days this year and I amazed how little utilities we use compared to being at home.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 11-04-2012, 07:57 PM   #32
thanks for that great information. I always enjoy reading your posts
Old 11-05-2012, 05:29 AM   #33
"As to lighting we have replaced everything except the Scamp Florescent
with LEDs. I believe the standard incandescent lamps produce about 120 lumens of decidedly yellow light. We have replaced ours with white LEDs of about the same lumen output."
What specific LED lighting did you use. Did you replace fixtures? Some say that they use replacement LEDs. Will you please clear this up for my muddy brain?
Old 11-05-2012, 06:09 AM   #34
Another question - what size wires should I run without knowing exactly what LED fixture I will be using and do I need a ground wire to each?
Old 11-05-2012, 06:20 AM   #35
Te PD9245 is designed to be used in an RV wih an existing AC & DC Distribution box, circuit breakers & fuses etc. It is only the power supply/battery charger part of the system.
The 9245 fits nicely in older boxes after the existing DC section is removed. I have installed several when the owner wanted to keep the original fuse and circuit breaker box.
Again, look at the PD-4045. It does the same thing, but includes the rest of what you will need, and often costs less for some reason or another.
Old 11-05-2012, 06:22 AM   #36
honda03842's Avatar
190 Lumen LEDs
These are the LEDs we are presently using. They are rated for 190 Lumens. You do not have to replace the fixtures as long as your present fixtures use any of these bulbs, 1141, 1156, 1073, 1093.
We have gone thru about 4 generations of LED lamps in our trailers as LEDs have gotten progressively better and these have been the best by far. They have been in place for over a year and some have a 1000-2000 hours on them.
They are not the least expensive, about $10 on Amazon.
Amazon.com: HQRP BA15s Bayonet Base 30 LEDs SMD LED Bulb White for #93 1141 1156 1073 1093 1129 Replacement plus HQRP UV Chain / UV Radiation Health Tester: Automotive
It ends up costing about $100 to do our Scamp 16. Beyond functioning better than incandescents, they comparitively last forever and produce a better more even light with voltage variations. In a year none have failed where I'm certain in a year of RVing we would have replaced the frequently used incandescents more than once.
(One property of Incandescent bulbs is that their life is dramatically shortened by high voltages, when your converter suddenly jumps to 14+ volts to desulfate your battery.)
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 11-05-2012, 06:28 AM   #37
Thanks Bob and, I'll say Honda since I don't know if Im talking to Norm or Ginny,
Honda, I don't have any fixtures so will have to purchase everything. There was only one LED when I purchased it and it was a plug in hanging light with the speaker plug. I don't think I will be using that one.
Old 11-05-2012, 06:30 AM   #38
Oops, here's my question - what sort of fixtures would you recommend and will they all sustain the same bulb or should I make sure of a certain wattage or voltage?
Old 11-05-2012, 06:30 AM   #39
If you have missing or older fixtures it is often cheaper to just replace the entire incandescent fixture with a new LED version.
These are the ones I have been using with good results. At about $14 each it's hard to justify using old fixtures and adapter style lights. The vendor also has a dual light version for about $24
68 LED RV Dome Ceiling Lights camper Trailer Marine Boat Cargo 12V Interior ZE | eBay
I have installed at least 20 of these in Scamps, BigFoots, Hunters and even in a 2013 Coleman hybrid.
Old 11-05-2012, 06:32 AM   #40
thanks Bob, I'll look at these. This is off topic but have you done rebuilds?
Old 11-05-2012, 06:35 AM   #41
Bob, once again this may sound stupid. I can't tell by the description of the light fixture if the bulbs are replaceable. Since you have experience with this particular fixture can you tell me?
Old 11-05-2012, 06:47 AM   #42
Darn it Bob, Seller from EBay does not ship to Canada. It looks like a great LED light, so will continue searching. Seems nice and bright. Jim
ON | 1975 Boler 13' Recently reconditioned, road ready $5250 KarenH Classified Archives 1 10-17-2012 01:41 PM
almost ready John Blizzard General Chat 5 05-03-2006 06:30 AM
Getting Ready General Chat 0 12-31-1969 07:00 PM
