Getting the Heater and Fridge going.... - Fiberglass RV
Old 06-07-2003, 09:32 PM   #1
So I have purchased a 1976 Trillium 13' and now I am trying to figure out how to work everything in it. The stovetop is pretty straightforward, but the fridge and heater are a little more of a mystery.
Where approx. is the pilot light on the furnace? Turn the dial to "pilot" and light it. easy right? now if I only knew where that pilot is...
Also the fridge. I thought it worked off of both electricity and propane. Plug the trailer in and the fridge should go, but how to make it work otherwise?
Any help would be great here. I am obviously very new to this, so help a newbie out please!
Old 06-08-2003, 03:04 AM   #2
Furnace: There should be a small door in the grill covering the furnace, open that. Remember this is inside the trailer and the door will come completely off. The dial temp setting is in there behind the door. There is a little trap door held in place with wingnuts, lossen the one that is higher and swing the door open. You can then light the pilot light for the furnace. Remember to close the little trap door.
Refrig: You need to remove the access grill on the outside to switch the controles on the fridge. 2 screws on the bottom and it comes off. Inside in the lower left there is a switch (red) for setting 120volt or 12 volt or off. The switch needs to be set at 120v or it wont work even if the trailer is pluged in. That just sets if any electricty is used, if you run off propane, set it to the off posion and turn on the valve to supply propane, then light the pilot light like a furnace. The access door to light the fridge is in the lower right side.
Hope this helps, if you need more info or what I have is not clear, please post again.
Rich
fridge
Can a 2-way fridge become a 3-way fridge? Rob Carmody Problem Solving | Owners Helping Owners 13 06-24-2016 10:54 AM
Fridge Help Chester Taje Problem Solving | Owners Helping Owners 4 09-21-2009 09:58 AM
4-way fridge Daniel V. Care and Feeding of Molded Fiberglass Trailers 7 03-15-2009 05:24 PM
Fridge Legacy Posts Problem Solving | Owners Helping Owners 15 08-09-2003 12:28 PM
Mr. Heater Buddy Portable Propane Heater Legacy Posts Problem Solving | Owners Helping Owners 16 08-03-2003 12:01 PM
