I am finally getting to the
Trillium 4500 that has come back to me after a number of years just sitting around gathering all kinds of stuff.
The plywood retainer block in the front, upper left corner that holds the aluminum track in place for the over the bunk cupboards has let go.
Everything is there, just sagged down a little. I have the insulation off all 'round and am ready to glue.
Is there a recommended brand/type/ that someone has used. I want this to be a permanent fix because I plan on finishing my time with this rig, however long that might be.
AND, what do you recommend for glueing the insulation back in place in all the areas where it has let go. The inside looks like me, all loose, sagging and wrinkled
Thanks in advance.... Scouter Dave.
