gluing closed cell foam to fiberglass - Fiberglass RV
Old 09-07-2015, 07:07 PM   #1
Trailer: trillium 1300
We are proud new owners of a 1975 Trillium 1300. Previous owners stripped the ensolite lining from the trailer interior, which led to indoor condensation, we discovered. We just purchased several sheets of closed cell foam to redo the whole interior, and are looking for the right glue to use. Any suggestions?
Also, the foam is lined (smooth) on one side. Is that the side we glue to the wall? Can the more "bubbly" side be painted?
bb
BerniceBaker is offline   Reply With Quote
Old 09-08-2015, 08:29 AM   #2
Trailer: 2008 Casita 17 SD
3M 77 Super Adhesive.
I like this stuff for contact adhesion. Works very well and makes a very strong bond. Not the cheapest stuff, but if you want to do it only once and be done with it...
Amazon.com: 3M 77 Super Multipurpose Adhesive Aerosol, Clear 16.75 Oz. Aerosol Can: Industrial & Scientific
Old 09-08-2015, 10:07 AM   #3
Trailer: Burro 13 ft
Weldwood Contact Cement - easy, permanent, and the bond is incredibly strong. It will eat certain kinds of foam like Styrofoam, but most everything else is good to go. I just redid a trim piece with contact cement after the Super 77 adhesive I originally used failed.
Scott Masterson is offline   Reply With Quote
Old 09-08-2015, 12:08 PM   #4
colinn's Avatar
Trailer: Trillium 13 ft
I have used this from Canadian tire. It is rated for headliners so the heat will not be a problem...
Permatex Heavy Duty Spray Adhesive | Canadian Tire
colinn is offline   Reply With Quote
Old 09-08-2015, 12:12 PM   #5
You should use 3M Super 90 it has a higher temperature rating than 3M 77
The fiberglass in direct sunlight gets extremely hot. Its a little harder to find though. You can check the ratings on the 3m website.
Old 09-08-2015, 01:08 PM   #6
Trailer: Boler shopping
If you can find it use Sta Put , it is superior to all the others listed In my opinion , I've used them all as a cabinet maker and after using Sta Put the others pale in comparison
AngryCrow is offline   Reply With Quote
goTenna... turns your cell phone into a cell-free 2-way text device accrete General Chat 3 09-01-2014 04:08 PM
Gluing new "rat fur" cannibal53 Modifications, Alterations and Updates 1 05-13-2013 08:58 PM
Anyone have experience with NU-FOAM vs Foam for seat cushions? Perseustheegg Modifications, Alterations and Updates 0 08-17-2012 02:20 PM
Volara - Closed cell foam for insulation Rob L Problem Solving | Owners Helping Owners 28 01-15-2010 10:24 AM
memory foam vs foam rubber mattress Phillip Problem Solving | Owners Helping Owners 11 06-28-2009 07:52 PM
