gray H2O tank repair - Fiberglass RV
Old 09-17-2006, 12:49 PM   #1
Trailer: Scamp 13 ft
The drainage tube that extends form my gray water tank (for connecting and dumping purposes) has broken off (some prior off-road travels). Now, I just have a gaping hole in the gray water tank on the underside of my Scamp 13 .
Could/should I repair this (if so, please share some ideas) or do I need to replace the whole thing?
adimiro is offline   Reply With Quote
Old 09-17-2006, 03:23 PM   #2
Paul and Libby Smith's Avatar
Trailer: 1994 19 ft Scamp 19 ft 5th Wheel / 2001 4wd 6cyl Silverado
Hi is the whole dump valve broken off the tank? if so I would probobly buy a new tank and valve assembly from scamp, you have 2 straps holding it up, plus a hose or two going in the top, its a cheap very lightweight product for its size, Paul Smith Orlando fl.
Paul and Libby Smith is offline   Reply With Quote
Old 09-19-2006, 08:27 AM   #3
Yeah, the whole dump tube/valve is history. I had no luck patching the initial crack (where the dump tube meets the body of the tank). THis seems like a weak point subject to alot of torque. Don't think that I would replace with the same, so looking for alternatives of other gray tank/dump valve designs.
Old 09-19-2006, 08:34 AM   #4
Have you tried to weld it...with a plastic welding gun? I'm talking about the tank. Harbor Freight Plastic Welder. I've never used one, but it seems to me there was a discussion at one time...maybe pre-hack
The dump valve assembly is just a standard, off-the-shelf at an RV supply store. Basically, it's just glued in, using something like JB-Weld . If you could cut that off and replace it, after fixing the tank...you'll be money ahead. I see from the 2005 Scamp parts list, they want $140, for a gray water tank and fittings.
someone also has installed a stainless steel gray water tank.....
Old 09-19-2006, 03:35 PM   #5
Brian B-P's Avatar
Fittings can also be "spin welded" to the tank, in addition to welded with the type of tool which Donna linked. There's a nice description of plastic welding alternatives in the Wikipedia page for Plastic welding. Yes, Donna, I remember the plastic welding discussion too, in which a forum member reported doing a tank repair this way; I have not done it myself.
I have seen a Boler B1700RGH with a stainless steel fresh water tank; the fresh water tank is the same size as the grey water tank, and similar in design, but of course with different fittings. It seemed like an expensive option, but the owner said he happened to know someone who did stainless steel fabrication cheaply.
rinsing out gray water tank? Christi V. Care and Feeding of Molded Fiberglass Trailers 14 07-14-2008 10:03 PM
Gray water tank for '91 Casita Geoffrey Cobb Problem Solving | Owners Helping Owners 1 10-11-2007 11:38 AM
Gray water w/out tank Janine Problem Solving | Owners Helping Owners 10 08-29-2007 03:06 PM
Gray Tank Drain Legacy Posts Care and Feeding of Molded Fiberglass Trailers 9 06-08-2003 06:50 AM
