Gray tank plugged up - Fiberglass RV
Old 09-16-2019, 08:11 PM   #1
I have a 2013 25B25FB and my gray water tank won't drain properly. I put a bunch of tank cleaner in and it helped but didn't solve the problem completely. Anybody know anything about the inside of the gray water tank?
Thanks;
Steve
Igo96047 is offline   Reply With Quote
Old 09-16-2019, 08:56 PM   #2
Thanks;
Steve
Sounds like the vent tube has a blockage or maybe the drain tube is kinked. Both situations can cause it to drain very slowly.
Air has to be able to enter to displace the volume of water that is exiting. So a compromised vent tube can significantly slow down the speed at which water exits the tank.
I don't know how the tank on your trailer is vented. But on my Sunrader I had a blockage in my tank because the vent pipe that went up to the roof fitting had slid downwards and was then beneath the level of the surface of the liquid. Which of course meant that there was no longer an effective vent as no air could enter the tank. Things like that can make it difficult to figure out the cause of the issue.
Old 09-17-2019, 11:23 AM   #3
Massachusetts
Have you tried giving it a good back flush, several times??
What have you or someone been putting down the drains, I am not referring to the cleaner here. Food scraps or whatever???
Lockman is offline   Reply With Quote
Old 09-17-2019, 11:31 AM   #4
Trailer: Jayco
Louisiana
Thanks;
Steve
If your vent isn't blocking air entry to the tank and the tank drain pipe isn't crimped, you could have the cutout remnants (construction debris) down in the tank blocking the exit. If so, you may be able to fish it out at the dump valve end once the tank is finally empty. You could push your garden hose up in there and give it a good rinsing, too. You may be surprzsesd at what all comes out besides clear water. I helped a buddy clear a solidified grease plug from his grey tank ... and his DW swore she never dumped any cooking grease down the drain!
Good Luck ........ Swampy
jimknoch is offline   Reply With Quote
Old 09-17-2019, 01:16 PM   #5
Fixed
Before leaving last location and heading home I went to Dollar Store and bought a small bottle of liquid dish soap. Poured it down both the shower and sink then drove 6 hours home. Seemed to drain OK this morning so think I got it.
Thanks
bigfoot
Battery, do I need one if plugged into electricty? Karalyn Electrical | Charging, Systems, Solar and Generators 19 06-22-2012 06:45 AM
Charging Battery and running battery lights when plugged in Nor_Cal_Todd Problem Solving | Owners Helping Owners 2 08-25-2010 01:44 PM
Help dead battery & still no lights plugged in- Mark J Problem Solving | Owners Helping Owners 8 12-09-2009 05:15 AM
Problem with lights while plugged in... Monica M Problem Solving | Owners Helping Owners 12 04-20-2009 09:35 PM
Do you leave your brake controller plugged in? Gina D. Problem Solving | Owners Helping Owners 7 06-20-2006 12:47 PM
