Gray water backing up while towing - Fiberglass RV
Old 10-22-2015, 09:28 AM   #1
Trailer: '00 Burro 17' WB
Seattle, WA
Just finished a 2000+ mile road trip in my '00 Burro. It towed beautifully and I am very happy with things with one exception. Seems that if I have more than a couple gallons of gray water in the tank, it sloshes up through the shower drain when I travel. I arrive at my destination with a wet and sometimes stinky shower floor. Very unpleasant. Anyone have the same experience and a solution? I often boondocking so will end up carrying gray water for a while before I can dump.
mglyons is offline   Reply With Quote
Old 10-22-2015, 09:39 AM   #2
IllAnnoy
Check the drain, if it is the same as the typical sink drain it will have internal threads which are made to accommodate a screw in plug.
You should find the plug at any RV shop. If it is not this type it might be a simple matter to switch. They are not at all expensive.
Old 10-22-2015, 09:45 AM   #3
Have had it happen in my Scamp but the grey tank needs to be pretty full before it happens when driving.
Only answer I have to it is as Floyd suggests making sure you have the shower plug screwed down tight.
I actually carry a smallish tote to drain off the grey water a little bit if I believe its getting close to full as I hate walking into the bathroom in the middle of the night and getting my feet wet
Old 10-22-2015, 10:11 AM   #4
Administrator
Mary F's Avatar
A more involved but excellent solution is one we did to our Casita: replacing the trap with a HEPVO valve.
HEPVO Waterless Trap on Casita.
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 10-22-2015, 12:53 PM   #5
I don't have a solution but the same thing happens to me if when the gray tank is fairly full. I always try to dump the tanks when possible before leaving a camp site. Since I never use the shower, I'm even thinking about capping off the shower drain so this doesn't happen.
ThomasE is offline   Reply With Quote
Old 10-22-2015, 02:40 PM   #6
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
Oliver installs a blade valve downstream of the shower drain to prevent this. It is controllable from within the shower/bath. That might be an option for you.
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 10-22-2015, 02:56 PM   #7
Dennis mn's Avatar
My response is exactly as yours!
2019 Airstream 19 Foot, pulled by a 2014 Nissan Frontier Pro4-X Crew Cab.
Dennis mn is offline   Reply With Quote
Old 10-22-2015, 03:01 PM   #8
Why wouldn't you just get the plug for the drain? Why make the shower inoperative?
Old 10-22-2015, 03:08 PM   #9
The Minimalist's Avatar
Louisiana
Are you towing with the trailer level?
Clif
Old 10-22-2015, 03:10 PM   #10
Trailer: 1999 Casita 17' SD
Ohio
Casita uses a blade valve on the shower drain.
As mentioned the installation of a Hepvo valve eliminates the rubber "J" trap and is maintenance free. Here's a U-tube of it.
Joe
Old 10-22-2015, 06:51 PM   #11
IllAnnoy
Don't forget that you go up hill and down hill and accelerate and brake.
Old 10-22-2015, 06:59 PM   #12
IllAnnoy
The Hepvo valve would not be relevant to Scamp since the drain/trap which I pictured above is all there is. It is connected to Tygon tubing from there to the gray tank.( a filter and a pump are used in line from the front bath)
Old 10-22-2015, 08:41 PM   #13
Louisiana
So true, but if the trailer is way out of level some of those actions could be accentuated.
Leaving no stone unturned............
Clif
Old 10-26-2015, 09:37 AM   #14
Seattle, WA
Thank you for all the good input. The trailer tows impressively level....except for all the bumps and lumps and hills that we encounter along the road. I'm going to start with the simplest solution, the cap. I also thought of trying the small flexible silicone "lid" that is designed to cover a drinking glass. Hopefully no more stinky wet mess.
Towing is easy, backing up?, well.... Pomfritz Towing, Hitching, Axles and Running Gear 67 09-11-2012 01:10 PM
Gray water, pumps, etc Suz Problem Solving | Owners Helping Owners 3 02-24-2006 05:09 PM
Gray/Black water sensors don't work Legacy Posts Problem Solving | Owners Helping Owners 9 08-11-2003 09:28 AM
Gray Water Backup Legacy Posts Plumbing | Systems and Fixtures 1 08-04-2003 06:49 AM
Gray Water Tank Leaking Legacy Posts Problem Solving | Owners Helping Owners 6 06-02-2003 10:04 PM
