Grease fittings? - Fiberglass RV
Old 03-12-2012, 05:52 PM   #1
Massachusetts
Grease fittings?
Enforce I crawl under the Scamp, I was wondering if the axel and or bearings have any grease fittings? You know , a nipple where one can pump in new grease. Thanks in advance.
Garycamper is offline   Reply With Quote
Old 03-12-2012, 05:53 PM   #2
Massachusetts
That should read "Before I crawl under..."
Old 03-12-2012, 05:57 PM   #3
Greg H's Avatar
Trailer: 72 Boler American
Indiana
I don't think so.
Old 03-12-2012, 06:40 PM   #4
Bill MacDermod's Avatar
Trailer: 1999 17 ft Casita Spirit Deluxe ('Inn EggsIsle')
if the bearing caps are solid there is no grease fittings, if the caps have a rubber disc in the face of them they usually have grease fittings, just pry out the rubber discs with a screw driver push your grease gun on and pump away while rotating the wheel
Bill MacDermod is offline   Reply With Quote
Old 03-12-2012, 07:15 PM   #5
Deb & Chuck's Avatar
grease bearings
If you have grease zerks under the rubber caps you can grease the bearings. If you pump to much grease in the grease will come out the back of the seal and get on the brakes.
Good luck.
chuck
Deb & Chuck is offline   Reply With Quote
Water tank fittings Peter_Crowl Problem Solving | Owners Helping Owners 13 05-02-2011 09:06 PM
Plumbing fittings? Jake Jacobson Plumbing | Systems and Fixtures 13 10-26-2008 04:13 PM
Where to Buy? New propane lines, fittings, etc? Kurt in BC Problem Solving | Owners Helping Owners 9 06-12-2008 05:27 PM
Exterior Fittings DanPatWork Problem Solving | Owners Helping Owners 2 01-09-2008 08:49 AM
Qest Replacement Fittings Victor Benz Problem Solving | Owners Helping Owners 0 07-28-2006 12:37 PM
