Grey water drainage backup question - Page 2 - Fiberglass RV
Old 10-15-2014, 10:51 AM   #15
Katie, I think Byron has the best suggestion, not sure you really need all that for venting...... may simple be a build up of gunk in the trap. Helped a friend replace the trap last year and it was jammed full of gunk.. nothing wrong it just needed a good clean out and the kink taken out of the drain hose attached to it.
Old 10-15-2014, 11:26 AM   #16
Idaho
Am I wrong in thinking if it were a drain trap problem that I'd still continue to have problems with it backing up (because the vent is distal to the trap)? Since allowing the air escape, I haven't had any problem with the drain at all. I figured the backup was mainly because I've attached a hose to the RV connection and created a long, small-diameter, closed circuit and therefore significantly increased the peripheral resistance. It didn't do this when I was emptying it directly into a buck using a short length of hose.
(20 minutes after writing above paragraph): For good measure (and piece of mind), I removed the drain trap to inspect for build-up and it was completely clear. I think the problem was my original suspicion about the air needing venting. I'm sure I'll tweak my system a couple more times before finding the perfect solution, but for now it's working really well!
Thanks for all the feedback!
katidesc13 is offline   Reply With Quote
Old 10-15-2014, 12:34 PM   #17
If it's working and you're happy with it, I wouldn't fuss with it. I related my experiences, but that doesn't mean it would be the same for everybody. I hope you're enjoying living in your Scamp.
Old 10-15-2014, 03:47 PM   #18
Just remember what you have now is an open vent to the sewer right by your side windows. When the drain isn't flowing gases can escape up the line. If it becomes a problem get a couple of sections of pvc and glue a coupler on one end then you can just slip them together and extend the existing vent above your windows. You don't have to glue it up solid.
Old 10-16-2014, 01:37 PM   #19
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Great job Katie, I was going to post my picture sooner but, you had it made ASAP.
FG bottoms and drainage Mike Magee Care and Feeding of Molded Fiberglass Trailers 5 10-12-2013 09:05 PM
Total noob question: grey water dumping? BCPaul Plumbing | Systems and Fixtures 29 01-09-2013 08:56 PM
Black water-Grey Water ROIDON L Plumbing | Systems and Fixtures 3 07-23-2009 06:09 PM
Gray Water Backup Legacy Posts Plumbing | Systems and Fixtures 1 08-04-2003 06:49 AM
