Grey water holding tank 76 boler 13 ft - Fiberglass RV
Old 05-09-2015, 10:55 AM   #1
Hello,
I am needing to get hold of a Gray water holding tank. I find it very difficult task as I don't know what I am looking for. There are several after market providers...but until I see one I won't know. Does anyone have a photo they could share or a description (dimensions etc)??
Many thanks
Michael
michael386 is offline   Reply With Quote
Old 05-10-2015, 09:09 AM   #2
Are you just draining the kitchen sink or did your's come with a shower too? I only have the sink to drain grey water so I just ran a host out the side to a decent sized bucket outside the trailer.
TimR is offline   Reply With Quote
Old 05-10-2015, 09:33 AM   #3
Micheal does your trailer have its original 76 built frame? If so you should know installing a built in grey tank may with its weight when full, be all it takes to push you into having to replace it.
A fast an easy alternative would be to get yourself a small tote and carry waster water container. Just attach a garden hose to the grey water outlet on the outside of the trailer onto the tank which would be located outside the trailer. An even cheaper approach is to get a large bucket with a lid (such as paint bucket) - cut a hole in the lid for the hose to fit in.
Edit to add: You may have a hard time finding anyone to share a photo of their grey tank on a 13' Boler as they where not common to the 13' - more common to find on the larger Boler's.
Old 05-10-2015, 10:02 AM   #4
Trailer: 1972 Boler 13 Foot
Grey water holding tank for 13 foot Boler
I have a 1972 , 13 foot Boler and don't have a grey water holding tank. All we have is a kitchen sink to drain and there's not a huge amount to drain each day. We put a buck underneath the drain hole and it works fine and simple to wash out when it gets grimy. It's simple and gets the job done well. Is there a reason you are looking to install a holding tank?, maybe I'm missing having something worthwhile .....
Boler Babe is offline   Reply With Quote
Old 05-10-2015, 03:28 PM   #5
Thanks for all the feedback. I only have the kitchen sink...to drain, but I am trying to avoid having to use the bucket ( which previous owner did) as in most campsites, it is not convenient to carry to appropriate dump site (or polite) just to dump it anywhere. I like the idea of a 5 gallon pail ( or whatever size would fit into storage area) with the lid...in fact I may use 2. With only draining the kitchen sink 2, 5 gal pails would last several days....I could then dump them when I leave the site or on the way out at the dump site. Again.....thanks....always good to hear what others think.
Old 05-10-2015, 03:31 PM   #6
I forgot to mention that I do not have the waste water "garden hose" outlet. Can someone share a photo of what that looks like. I have the fresh water input connection.
Old 05-10-2015, 04:52 PM   #7
jkmboler's Avatar
Trailer: 1974 1300 Boler
Manitoba
The waste water "garden hose" outlet is just like your fresh water input connection, just the opposite gender fitting.
I use a plastic 5 gal water cooler jug. It even has a convienient carry handle molded into the jug.
You will want to replace your sink drain hose, re-routing it to a male garden hose fitting (any RV shop will have a selection) out the side of the camper. Then a short length of garden hose (with a female fitting) to drain into the jug.
1974 Boler 1300
Manufactured in Winnipeg, Manitoba.
jkmboler is offline   Reply With Quote
boler
Replacing Grey Water Tank 1978 17 foot Boler ggdub Care and Feeding of Molded Fiberglass Trailers 2 07-19-2011 06:41 PM
Grey Water Tank Sensor Tamid Problem Solving | Owners Helping Owners 7 09-13-2010 02:06 PM
hole in grey water tank Joseph and Melanie Castine Problem Solving | Owners Helping Owners 5 09-11-2008 12:02 PM
Leaking Grey Water Tank on Boler KevinDR Plumbing | Systems and Fixtures 7 09-01-2007 10:12 AM
