Hi,
We just purchased a used (2007) 16'
Scamp - we are completey new to travel trailers. While going through and cleaning all the nooks and crannies, I opened up the under-bench space where the fresh water tank is located. In that space, I noticed a blue/white striped hose which came from the grey water tank (I believe) but just stuck up in the air. Nearby is a hole out the bottom of the floor where it looks like this hose was once directed out of the trailer floor - there is a bunch of caulking around the hole which probably sealed the hose in place.
I am assuming that this is the grey water overflow hose which has come loose from its outlet hole. The problem is that, for some reason, the hose barely reaches that hole. Maybe it was cut too short to start with or somehow broke, but it looks like it will need to be replaced. I can't find this hose as a 'part' in the
Scamp site 'Parts Store'. Any idea where I can get a longer length of this hose? Is there a particular name for this type of hose?
Thanks!
