Grounding Tail Lights with no White Wire - Fiberglass RV
Old 08-10-2010, 10:47 PM   #1
Trailer: 76 Trillium 13 ft
I've purchased some replacement tail lights for my Trillium 1300 from Princess Auto. They Unfortunately only have wires for the brake and signal lights, no white wire for ground. If I use one of the 2 wires for ground then I only have running or brake/signal lights. How do I add a ground so they function properly?
Thanks in advance
Tim
Tim Bas is offline   Reply With Quote
Old 08-10-2010, 10:52 PM   #2
Perry J's Avatar
If the reflector is metal simply screw a ground, white, wire into the reflector
of other metal part of the light.
Old 08-11-2010, 03:27 AM   #3
Doug Arthurs's Avatar
Trailer: Boler
The mounting bolts are normally the ground. They assume you are mounting the lights to a steel trailer. Just put a loop terminal on a length or wire that is attached to your trailer frame and put the loop on one of the mounting bolts. Always scrap the paint off the frame where you attach the ground to ensure a good connection.
Doug Arthurs is offline   Reply With Quote
lighting, lights, tail lights
new tail lights Vicki A. Problem Solving | Owners Helping Owners 6 02-14-2010 04:48 PM
White LED lights at Princess Auto Steve Alexander Care and Feeding of Molded Fiberglass Trailers 4 06-13-2009 10:30 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
New Tail Lights - Help! Sitah Problem Solving | Owners Helping Owners 13 07-12-2006 10:43 AM
Tail lights Legacy Posts Problem Solving | Owners Helping Owners 32 07-27-2003 09:29 AM
» Trailer Showcase
The Lemon
Whis
Camper
bfrazier
