Halp! No 12 v power - Fiberglass RV
Old 06-03-2016, 05:28 PM   #1
Weavery's Avatar
Trailer: Escape 5
Halp! No 12 v power
Hi
We just set up camp in my new to me 2002 19' Scamp. Have used it several times this spring with no problems. The 12v stuff worked just fine when we set up 2 hours ago and now nothing works and the power converter fan is off. Have checked breakers, replaced fuses, checked battery connections.??
What to do? 4+ hours from home. Never used the crank for the front legs.
Jean
Weavery is offline   Reply With Quote
Old 06-03-2016, 05:41 PM   #2
Are you connected to 120 volt power ? Is any of your 120 volt appliances working
Old 06-03-2016, 05:48 PM   #3
Weavery's Avatar
Trailer: Escape 5
Yes, all that works fine and apparently the front legs are wired into the battery as they still work so we can get home.
Old 06-03-2016, 06:13 PM   #4
Trailer: Compact Jr and Teardrop Trailer
Sound like a fuse someplace blew.
Jeremy
rainjer is offline   Reply With Quote
Old 06-03-2016, 06:22 PM   #5
Weavery's Avatar
Trailer: Escape 5
I replaced the 4 fuses in the converter and flipped the breakers. Are there more fuses?
Old 06-03-2016, 06:41 PM   #6
Originally Posted by Weavery View Post
... Are there more fuses?
Usually one under front bench, often wrapped up and hard to find. And of course the one very near the battery.
See also this: http://www.fiberglassrv.com/forums/f...tml#post590893
Old 06-03-2016, 06:53 PM   #7
A 14 year old trailer could easily have some modifications. The electric jacks or stabilizers could be wired directly to the battery thus avoiding the main fuse panel. A fuse to the supply to the 12 volt distribution panel could be bad. If it was owner modified, it's any ones guess.
Old 06-03-2016, 07:18 PM   #8
In fact the electric jacks are a dead giveaway that something has been changed or added. If one knew how they were wired (and one should know if they have them), then you might be able to get closer to a conclusion. In fact, it could be nothing more than the converter 120 VAC plug fell out, if there is one... more info needs to be known and some testing with a meter will reveal the problem.
Old 06-03-2016, 10:22 PM   #9
Trailer: Scamp 13
Did you run your fridge on 12 volts and leave it on? Running the fridge on 12 volts on a poorly set up tug during travel will drain the battery while the fridge sucks the life out of the battery.
Old 06-04-2016, 04:53 AM   #10
Weavery's Avatar
Trailer: Escape 5
Frig is 120v or propane. No 12v option. I found the fuse under the bench and changed it was no luck. I don't have the right size for the in-line fuse at the battery. Since the legs work we can get home. Will hope the repair shop at home can solve it before our next trip.
Old 06-04-2016, 05:19 AM   #11
Weavery's Avatar
Trailer: Escape 5
Just noticed a tiny red light on the power converter that says "overload". It appears to be glowing. I pulled the 4 fuses and a couple were warm. And clues?
Old 06-04-2016, 11:53 AM   #12
This is like trying to solve a jigsaw puzzle with only a quarter of the pieces.. but there might be a few clues in your postings.
1. You sound almost sounded surprised that the converter fan was not running (first post). Normally the converter fan runs only when the converter is under heavy load, and that is normally the exception and not the norm. If your converter fan runs continuously or nearly so then I would suspect that it is being overloaded and I would want to know why.
2. Warm fuses are unusual but I suspect that they were warm just because the thing they were plugged into was warm. If the converter is warm it could be normal or it could be a sign that it is being overloaded.
3. The jacks are a complete wild card. They might have nothing to do with your problem, or they might have everything to do with your problem.
In all of the above cases, I would want to see the camper inspected by a qualified and experienced person to make sure there is not a dangerous situation present.
Old 06-04-2016, 12:45 PM   #13
NW Wisconsin
Some of the older Scamp converters have two relays . When you plug into shore power the relays are energized and one of the relays transfers your 12VDC loads from the battery over to the converter's
12 VDC power supply . The other relay connects the battery to the converter's battery charger. The relays have both N/O & N/C contacts which have been known to fail or make poor contact.
One of the relays failed in my 1999 Scamp and I lost my 12VDC.
Repairing the converter is not difficult but it is not a job I would tackle without proper tools , a meter and a schematic.
Old 06-04-2016, 04:34 PM   #14
Weavery's Avatar
Trailer: Escape 5
I called a local rv service shop. My big concern was safety. They assured me the camper was safe, no fire risk. After 14 years of service I am happy to replace the converter. I have a Tuesday appt to drop it off at a shop at home to replace the converter and check the wiring. Our next outing is June 22 and they promised to have it done then.
I really appreciate sveryone's comments. I feel like I understand the problem better.
Thank you!
Old 06-04-2016, 05:46 PM   #15
Ttocs M's Avatar
Trailer: Formerly Scamp
Unhappy FYI - blown fuse
On a kayak trip last fall to the Washington coast, I picked up my recharged battery and was surprised to find I had no 12v power upon arrival. Discovered the serviceman hooked up the battery to the wrong terminals, blowing the inline fuse. I now carry lots of extra fuses.
Still learning ow to troubleshoot my FRG.
Ttocs M is offline   Reply With Quote
Old 06-04-2016, 05:53 PM   #16
NW Wisconsin
After reading all these posts about batteries being hooked up backward , I marked the position wire to the battery with red tape and the negative wire to the battery with black tape then sprayed both wires with clear spray paint. I then painted the top of the battery post red for positive and black for negative..
new level and power gauges Joe MacDonald Modifications, Alterations and Updates 8 12-12-2005 06:37 AM
12v vs 110v power - what goes where in Scamp? TomN Care and Feeding of Molded Fiberglass Trailers 20 11-26-2005 11:51 AM
Power cords Legacy Posts Problem Solving | Owners Helping Owners 14 03-28-2003 10:16 AM
Power Caster Adapter Legacy Posts Modifications, Alterations and Updates 2 02-05-2003 01:15 AM
Power cord hatch/door Legacy Posts Electrical | Charging, Systems, Solar and Generators 11 10-17-2002 05:46 AM
