hand pump faucet lost it's prime, What's easy way to prime it? - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Problem Solving | Owners Helping Owners
Click Here to Login
Old 04-07-2007, 02:22 PM   #1
Trailer: 2005 13 ft Trillium Outback
Over the winter, I left the handle of the pump faucet in the wrong position after winterizing. Now the faucet has lost it's prime and no amount of pumping the hanlde will suck enough water up the two foot of vertical rise in the hose.
Do I need to funnel water in thru the nozzle and down the hose?
Do I need to connect a serious vacume source to the nozzle and suck the water up?
Do I need to disconnect the hose under the sink and manually prime the hose and re-attach?
Do I need to give up and install an electric pump and/or another faucet?
I looked at Patrict's info on installing a water pump and it is tempting.
Thanks
Curt
2005 Trillium Outback w/ 30" tongue extension
1989 Award 730, 30'
2003 PT Cruiser
1998 K2500 Chevy Silverado 6.5 Turbo Diesel, 4X4, ext cab, short bed
Curtis F. is offline   Reply With Quote
Old 04-07-2007, 02:24 PM   #2
Robert Scallan's Avatar
Trailer: 2007 Scamp 13 ft / 2005 Jeep Wrangler 6 cyl
Send a message via Yahoo to Robert Scallan
Talking
Thanks
Curt
The factory installed a hand pump on mine new 13 by mistake(already has an electric pump.....I'm sure they will sell you pretty cheap. I'm going to install a in line filter so that I can use the hand pump for filtered water for drinking etc...
Robert Scallan is offline   Reply With Quote
Old 04-07-2007, 08:01 PM   #3
Unhappy
Even my Fiber Stream's electric water pump looses it's prime on occasion. I have heard that if you plug the end of the faucet with your finger while pumping, you can get your prime back.
I have
connect(ed) a serious vacume source to the nozzle and suck the water up
while running the pump.
Old 04-07-2007, 08:35 PM   #4
Trailer: 1981 13 ft Scamp ('Dacha' Russian summer house) / 2006 Tacoma V6
I converted my Scampto electric. Easy little project, about $30 and flows strongly.
jim munson is offline   Reply With Quote
Old 04-07-2007, 11:18 PM   #5
Hi Curtis, if you have a compressor, you could blow air directly across the end of the water faucet, not into it but just across it, and the vacuum action should start your prime...you can also try and blow it at an angle away from the faucet......good luck...Benny
Old 04-08-2007, 09:01 AM   #6
Roger H's Avatar
The pumps on the sinks of these trailers are self-priming. If yours doesn't prime, then its either due for a re-build, or (more likely) a replacement. It means the gaskets inside have worn to the point that they won't seal any more. In the days of yard pumps on wells, the gaskets were leather, and could be renewed (cause them to swell) by pouring water down the top of the pump. All of these have rubber (and cheap rubber at that) gaskets that have to be replaced.
Sometimes it is possible to do the "finger-over-the-spout" bit, but if that doesn't work, or it doesn't hold prime after that... well... then it's time to get the tools out.
Roger
Old 04-08-2007, 05:14 PM   #7
Lizbeth's Avatar
Trailer: 1979 13 ft Boler and 1987 Bigfoot 5th Wheel
Suck on it if you can get your head in that tiny sink.....
The finger over the opening usually works for me.
Old 04-08-2007, 08:03 PM   #8
Finger trick didn't work. Can't get head in sink to suck on it. Has very small down spout to attach hose to. I'm going to put a centrifical pump inline so it will restore prime anytime prime is lost. Have to test out if pump will flow water thru pump side of faucet. If not, I'll be wanting to install a valve to switch the pump between second faucet and pump faucet. Just haven't figured out where to put valves in line to switch pump flow. Centrifical pump is non-self-priming so has to be mounted below water level to work. Got nice spot next to water tank for it. Will have to experiment with the valving needed. Am going to have to have a valve on the line to the second faucet to keep from sucking air when trying to hand pump. Suspect I will need second valve on line to pump faucet to close the line when I want to use the second faucet.
It would be too easy to disconnectthe pump faucet from the water tank and only use it for city water connection. Have to make it a plumbers nightmare.
1989 Award 730, 30'
2003 PT Cruiser
Old 04-09-2007, 04:25 AM   #9
Curt,
I'd suggest installing a rebuild kit in the hand pump before going any further. Many years ago, we had similar woes in a truck camper. As I recall, the rebuild kit was quite inexpensive, simple to install and they were available at just about any camper supply store.
Of course, if you enjoy the process of creating "Rube Goldberg" projects when they might not be necessary...go for it and have a ball
This advice from a person who has spent way too much time and money over the years on similar endeavors, only to realize too late, the error of my ways.
Too soon old, too late smart, and now prefer to practice the "KISS" (keep it simple, stupid" principle).
Kurt & Ann K.
Old 04-09-2007, 06:27 AM   #10
Roger H's Avatar
I've gotta agree... and even if your pump isn't re-buildable, a new one is only $25 and a whole lot less aggravation than trying to install an electric.
Roger
Old 04-09-2007, 10:22 AM   #11
Christi W's Avatar
Trailer: 1987 17 ft Burro
Hi Curtis -
My hand pump in the Burro didn't work and I thought it might be the washers also. Took the entire uniit to an rv place. He pumped and could feel some suction , but not enough to pull two feet. Turned out it was a small hole in an old rubber hose. We just needed a new hose and a better clamp.
Ours was pretty easy to detach and you can put it in a more comfortable position to see if there is any suction or not.
Good luck.
Christi W is offline   Reply With Quote
Old 04-09-2007, 10:51 AM   #12
Trailer: 1982 13 ft Burro
FWIW, I repaired my pump gasket with rubber cement and it's held up for a year or so. For the amount of work it is to dissassemble the pump, you'd be better off ordering a real rebuild kit or a new pump -- I just lacked the foresight to do either of those things.
AndyW is offline   Reply With Quote
Old 04-09-2007, 11:05 AM   #13
This is the type of faucet that I have. J&C dual action faucet The large connection is for city water line. The small is for the feed from the fresh water tank. It is a major pain to reach from the refrigerator hole, above the heater, and around the sink to get to the underside of the faucet. I know because I had to replace the original 2 years ago. It was defective or damaged when it was installed.
The pump does generate a vacumn, but loses most of it during the next stroke, so is unable to pull water up the hose.
Rube is my hero
Curt
1989 Award 730, 30'
2003 PT Cruiser
Old 04-09-2007, 11:28 AM   #14
The Trill must have a sink like a home kitchen one, where the faucets go thru the sink ledge...on my 13' Boler, the faucets go thru the counter top and for accessability, I disconnect the drain and remove the sink hold down hardware and the sink lifts out and voila...total access to the faucets under the counter.....my manual pump takes a while to prime so I use a piece of surgical plastic tube and suck the water up from the tank thru the manual pump faucet, then it`s good for the rest of the year pretty well.....I use a single handle pantry faucet, (goose neck type), for our water from the park pressure system.....Benny
Old 04-09-2007, 12:18 PM   #15
NO, the faucet goes thru the counter top only. The sink is held on at four corners underneath by wing nuts and "L" brackets. Even harder to reach and remove than the faucet. Although removing the sink would give access to make the removing the faucet easier. Removing the sink would just make more work to gain access to make it marginally easier to remove faucet.
Curt
1989 Award 730, 30'
2003 PT Cruiser
Old 04-09-2007, 05:58 PM   #16
It was really easy to in stall a SELF PRIMING ELECTRIC pump at the outlet of the tank.
Working for three seasons now.
Old 04-10-2007, 05:00 PM   #17
Pete Dumbleton's Avatar
My 91Scamp13's faucets (manual pump and city water) are mounted to the cabinet (not the sink) also.
There may be some crud in the bottom of the chamber causing the ball valve to seat improperly.
I once sprayed silicon in a manual pump and that was a mistake for that pump's components because the silicon caused them to bind...
Hand Pump Faucet Priming and Holding Prime? Kevin Poll Problem Solving | Owners Helping Owners 5 06-13-2010 07:37 AM
old Coleman Hand Rocker Pump Peggy Problem Solving | Owners Helping Owners 1 08-28-2009 09:05 PM
Prime Rib/ Porter house sherry loving o Camp Cooking, Food & Recipes 1 03-29-2009 08:12 PM
No more hand rocker pump.... kentj Modifications, Alterations and Updates 7 07-18-2008 01:15 AM
Losing prime in water system Paula D. Plumbing | Systems and Fixtures 19 06-07-2006 12:58 PM
