Hand Pump Faucet Priming and Holding Prime? - Fiberglass RV
Old 06-11-2010, 08:57 PM   #1
Kevin Poll's Avatar
Trailer: 1975 Trillium 13 ft / 2002 Honda Odyssey
Hi all,
Our trillium (circa 1975) has a hand pump faucet at the sink that is connected to a 12 gal storage tank that we haven't used before. The pump is chrome with a round black plastic ball on the end of the pump handle and the sticker on the underside has a coleman logo on it.
I am trying to get everything up and running and have a few questions for anyone that uses this setup: 1. what is the best way to prime the hand pump or should it be self priming? 2. once primed ( i had to suck the water up into the valve body to get it working) how long should i expect the pump to hold its prime? I have already trimmed and re-attached the 3/8" water line going to the tank (it is PE plastic and had little stress cracks in it at the barb fittings that were letting in some air) but I am now tempted to replace the line altogether with something that isn't 35 years old.
I want to make sure my expectations for how this pump should work are realistic.
thanks,
we are trying to get everything ready for a 3 week trip through new brunswick leaving next thursday but the past few days things are coming apart faster than I can get things together.
Kevin
Kevin Poll is offline   Reply With Quote
Old 06-11-2010, 09:10 PM   #2
Trailer: 13 ft Scamp / Silver Ford 150
I was sufficiently annoyed with the new pump that came with my new Scamp - wouldn't hold its prime at all - that I bought something called the Rocket Hand Pump from Amazon - under $30, that seems to hold its prime for days. It's also self priming. I like it a lot.
barring is offline   Reply With Quote
Old 06-11-2010, 09:30 PM   #3
Joe Z's Avatar
New River AZ
That's a nice hand pump and it got good reviews;
http://www.amazon.com/Valterra-Products-RP...3187&sr=8-1
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 06-12-2010, 12:54 PM   #4
Larry C Hanson's Avatar
Hello Kevin,
The new hand pump I installed on my Trillium would not hold a prime... water kept draining back to the tank.
The cure was a small 'check valve' installed in the supply line just below the hand pump. Now the hand pump
pumps on the first stroke every time. Here is the valve I used:
http://www.usplastic.com/catalog/item.aspx...9&catid=489
Good Luck,
Larry H
Old 06-12-2010, 08:11 PM   #5
Kevin Poll's Avatar
Hello Kevin,
Good Luck,
Larry H
Thanks Larry, that'll be the ticket.
that looks cheap and easy to install, I'll keep my eye out for one and I think I might install it where the line connects to the holding tank (easier to get at).
great advice.
Old 06-13-2010, 07:37 AM   #6
You are welcome.
I ordered two valves directly from the company. As I recall the shipping was reasonable and quick.
Larry H
Priming a Coleman Rocket Pump amanda r Problem Solving | Owners Helping Owners 3 04-29-2010 07:03 PM
broken hand water pump cyndi H Problem Solving | Owners Helping Owners 21 10-21-2008 05:58 AM
No more hand rocker pump.... kentj Modifications, Alterations and Updates 7 07-18-2008 01:15 AM
Hand Pump Water Fixture Brian T Problem Solving | Owners Helping Owners 1 05-28-2007 05:36 AM
hand pump faucet lost it's prime, What's easy way to prime it? Curtis F. Problem Solving | Owners Helping Owners 16 04-10-2007 05:00 PM
