Has Anyone Changed The Front Crank Stand to One With a Wheel?? - Fiberglass RV
Old 07-29-2007, 08:40 AM   #1
dapple's Avatar
Trailer: 1973 Boler
If the front stand had a wheel, the Boler could be moved so much easier
Hello Again,
Another post from me!!! I have so many questions.
I had an old tent trailer, and the front stand crank had a wheel. Two people could move this trailer NO problem.
My 73 Boler is around the same weight if not less........but it has an old crank down stand with no wheel.
Has anyone replaced theirs??? Any idea of where to get one with a wheel that will fit??
Thanks.
Sue!!
dapple is offline   Reply With Quote
Old 07-29-2007, 09:20 AM   #2
Trailer: 1992 Bigfoot 17 ft
Hi
You may want to try Princess Auto in Whitby (Thickson exit 401 South)
Norm
Norm Wyndham is offline   Reply With Quote
Old 07-29-2007, 10:06 AM   #3
colin k's Avatar
Trailer: 73 Boler
I replaced my whole crank stand and it had a wheel already. Only problem was now the stand was too high and you couldnt lower it enough to get the rear jacks down to the right height. So. I cut off the wheel and welded the old plate on where the wheel went. The jack was purchased at PA. So. If you find a wheel make sure you can crank the jack in enough to utilize your rear stabilizers.
colin k is offline   Reply With Quote
Old 07-29-2007, 10:38 AM   #4
Trailer: 1970 Boler
I have one as well.....its pictured on my website.
Its a little high as well but definitely easier than the stand;
- Kurt
Kurt in BC is offline   Reply With Quote
Old 07-29-2007, 12:45 PM   #5
Con
Trailer: 1977 Boler 1300/2003 17' Bigfoot
Princess Auto-$24.95 plus taxes. Flips up along the frame and gives the frame some protection in case you jack knife.
Can move the trailer around with one hand. I recommend replacing the bolts that come with it with stainless steel bolts and SS nyloc nuts.
In that location they would rust up fast!
Con is offline   Reply With Quote
Old 07-29-2007, 04:10 PM   #6
Trailer: 1978 Volkswagen Westfalia
On my father's Shasta he had both. On the post that comes down, there was a wheel that could be lifted up and slotted up when hitched up to the car. I know I'm not explaining it right but maybe someone else out there knows of something like that. It wasn't a separate thing, it will still part of the hitch.
Jan Adams is offline   Reply With Quote
Old 07-29-2007, 04:14 PM   #7
Trailer: 1991 16 ft Casita Freedom Deluxe
Just a thought but I prefer to have a skid on the bottom of my tonge jack to help prevent an inadvertent runaway trailer. Yes, you should chock your wheels before unhitching, but...
If you want to move the trailer around, how about getting a tongue dolly like one of these?
http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=37510
Lee Hillsgrove is offline   Reply With Quote
Old 07-29-2007, 04:23 PM   #8
Pete Dumbleton's Avatar
I replaced my wheel-less swing-down jack with one with a wheel and found out that the two different brands of jack did NOT use the same diameter swivel ring...
Old 07-29-2007, 04:35 PM   #9
Trailer: 1970 Boler
I have the same one as Con. Can't beat that price.
Old 07-29-2007, 05:57 PM   #10
I changed my tongue jack to one with a wheel and found one disadvantage...if you are on a sloped driveway, the trailer won`t stay put but will roll and if you are alone it becomes a problem when moving the trailer and then trying to chock the wheels and hold the trailer from rolling....Princess Auto here sold a jack with a brake on it but I didn`t buy and maybe should have.....I use the trailer dolly and have to turn it 90 degrees to the tongue so one of the dolly tires jams under the tongue and the trailer doesn`t roll......the good part about the new tongue jack is that if the driveway is flat you can push the trailer around by pushing on the cabin........when I went to install my jack, I found that because of the height of my trailer tongue, I had to fabricate mounting brackets so the the jack sat higher and I could drop the tongue lower when stting up in some camp ground sites.....you can see what I mean in my webshots site pics.....Benny
Old 07-29-2007, 08:04 PM   #11
CindyL's Avatar
Illinois
We added a boat one to our Burro that we bought at a Bass Pro Shop. We did not take off the other, just left it on but in the up position and did not use it.
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
CindyL is offline   Reply With Quote
Old 07-29-2007, 10:59 PM   #12
jaye580's Avatar
Maine
I just bought the wheel... drilled a small hole through the original stand and when I need to use the wheel I crank the front up with a jack, slide the wheel in, put a bolt with cotter pin through the hole, move it around and then take the wheel off. It sounds like work, but for as often as I need this feature it isn't too bad. On Scamp one I did put the swing up kind on that has the wheel attached, but on Scamp two with the tongue box, I don't have room for the swing!!
Come to think of it though, my bday is coming up and I would like to have one of those trailer dollys... since I have a snowmobile, a utility trailer and a couple of ATV's I could justify having the trailer dolly if I can talk the kids into buying it for me!! LOL
I might mention that I have had Scamp 1 get away from me though... had a slight hill on the driveway and once while rolling it around manually, it started moving faster than I was prepared for and being as though I was alone and couldn't get anything behind a wheel to stop it I was about to be in big trouble! Luckily a neighbor was watching and ran over to help- now when I am pushing it around I keep a block more handy to put behind that front wheel if need be!
Owner of 1978 Scamp named the KRAKEN
Owner of 1987 Scamp named ANBOLINN
https://www.facebook.com/Jayes-87-L-...0486405460995/
jaye580 is offline   Reply With Quote
Old 07-30-2007, 07:43 PM   #13
dapple's Avatar
Trailer: 1973 Boler
[quote]Princess Auto-$24.95 plus taxes. Flips up along the frame and gives the frame some protection in case you jack knife.
Attachment 9205
Hi there
I didn't see the one for $24.95. I've attached the pic of the flyer. Let me know if the one you are talking about is on there!
Thanks!
Sue!
Old 07-30-2007, 10:25 PM   #14
Con
If I remember correctly it was the 1000 lb. swivel jack Item 1070020. That is the regular price but they the have them on for the sale price of $24.95 every so often. I think the last flyer I had showed them on sale again.
If you mount it with the bottom bolts tight up against the bottom of the frame it still gives you enough movement to set the trailer level when you park. At least with the Boler it does.
Common sense tells me that if I am going to to move the trailer around on a sloped driveway or ground I am going to have a wheel chock in my hand. A shop dolly is fine when you are at home but its no use to you when you are out in the boonies. That caster wheel sure is though.
Scamp Trailer Crank Wheel/No Wheel Mitchell Problem Solving | Owners Helping Owners 6 08-25-2008 11:36 AM
Looking for a pedestal table stand Mike Montville Problem Solving | Owners Helping Owners 9 04-03-2008 10:29 PM
Front lift wheel on a 17 Herb P Problem Solving | Owners Helping Owners 9 05-12-2007 09:42 PM
Wheel Jack in Front Steve B Modifications, Alterations and Updates 5 06-29-2006 03:02 PM
5th wheel front bathroom Legacy Posts Problem Solving | Owners Helping Owners 3 06-28-2003 06:30 PM
