Old 10-06-2006, 11:45 AM   #1
josh
Guest
Posts: n/a
Hello all,
I'm the proud new owner of a 19' Bonair oxygen. I would like to install a gas furnace for those chilly fall/spring nights. However, I've been told it will be difficult due to the lack of flat wall space for the vent.
Looking for options,
Josh
Old 01-04-2007, 06:55 PM   #2
Trailer: Bonair Oxygen 2002
We use a little electric ceramic micro-furnace
Works well
There is a hose under our bench by door and I think a mark on the fiberglas where you can punch out an opening. I called to an Alberta Dea;er who had sold a number of trailers and had installed something like a top of a butane heater to the hose and sat it on the floor. I didn't like the sound of that -hence the $40-50 heater.It was June in Michigan - got the last one to be had then - had to go to camping world to find one. Any hardware store we found had sold their's off in the winter. We weren't picky- just freezing cold. It had started to wartm up again by the time we found a heater !
jean
norman and jean mulloy is offline   Reply With Quote
Old 01-05-2007, 12:38 PM   #3
Brian B-P's Avatar
RV water heaters are generally designed to mount in a flat exterior wall, and the solution is mould a surrounding adapter (or transition piece) in fiberglass, which is visible in photos of trailers such as my Boler 1700 (see the same setup on a different variation of B1700 in an Album photo). With the water heater, it's a large square heater door, so the whole thing is quite a wart on the curve of the trailer, but for a typical furnace vent it could be quite small and blend in much better.
furnace, oxygen
pricing for a bonair oxygen??? landry yves General Chat 4 09-08-2009 07:51 AM
Looking for a Bonair Oxygen trailer Norm Babin Wanted: Molded Fiberglass Travel Trailers 2 03-09-2009 08:45 PM
Just purchased '02 Bonair Oxygen Trevor and Tracy General Chat 47 07-19-2007 08:55 AM
oxygen by bonair Legacy Posts Care and Feeding of Molded Fiberglass Trailers 29 12-26-2002 10:44 AM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
