I want to thank everyone for the advice and links. On Sat I managed to drive to a RV dealer who is South of me. ( RV Warehouse) I really wanted to see it they had anything in stock. I managed to match the hatch for the power cord. I am changing the three other hatches to round boxes/covers. The mounting of the water ones should fit as the old ones are pretty close together.
Do you think that the round ones will cover your existing cut-outs okay? This is my main reason for not going that way, as it would mean doing some body work.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
I already replaced it with the square one. The back is round as it goes into the trailer so the round one would have worked good.
So my idea of using the City Water hatch for the sink and changing the hose end to a male will not work. There is a one way valve in the City Water one so it would not allow the sink to drain. Back to the catalogues.
Do you know if all the holes are round? My trailer is out at our land, and I can't check.
2017 Escape 5.0 TA
Going to have a look at the valve tonight to see if it is removable. I know I can get and adapter for the threads.
Will do Roy. I'll be as careful as I can taking the others off but they are pretty brittle.
The power cord was a large round hole. The city water and sink drain are round olds with a neck on them. So there is a tube about 1 1/2" that it goes through. I'll go have a look and take a pic.
Looks like the penetrations are very small, compared to the hatches. That's a good thing.
2017 Escape 5.0 TA
That's fine, Don. The photos tell the story very well, thanks.
2017 Escape 5.0 TA
Ok problem solved. I looked through my plumbing parts and have an adapter. The male end threads into the the round drain hatch and the other end of the adapter threads on to a hose. So all I have to do is remove the one way valve which seems to be plastic.
