Hello and help re Water leaking in around door - Fiberglass RV
Old 08-06-2012, 12:45 PM   #1
Trailer: Boler - Est 1974
Yukon
Hello!
I am a new owner of a 74 ( i think) boler purchased in Alberta and brought to its new home in Yukon.
On the trip, I was able to discover that everything seemed to work perfect ( original fridge, stove and heater) but that there was water getting in somewhere.
It appears to be getting in through the door frame, while the trailer is being towed. You can clearly see the water hitting the front of the trailer, and then the line stopping dead as it enters into the door frame. I have replaced all the original draft stop material, and tried to build up a strong seal, however, when hit with a jet stream from the hose, water is still getting in.
Has anyone a) had this issue and b) experimented with some sort of guide or overhang in front of the door to sweep the water over this area?
Any suggestions would be appreciated!
Tracy
PS - any idea how to determine for sure the year of the boler? the registration says 1964 ( clearly an error) and all the stickers I can find are so faded I cant read them...
Sahara is offline   Reply With Quote
Old 08-06-2012, 12:58 PM   #2
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Hi Tracy, and welcome. I would imagine that some other folks have had a similar situation and will be able to chime in with ideas. I know that on my former Burro, the previous owner had added a piece overtop the doorway because it was a known issue with Burros.
Old 08-06-2012, 01:36 PM   #3
Trailer: scamp 13
thats not a bad idea. you could test it with some good double stick tape and a piece of vinal molding,,, or aluminium or something. maybe have to try a few shapes to find one that works
Leaking Grey Water Tank on Boler KevinDR Plumbing | Systems and Fixtures 10 09-10-2021 07:53 PM
Water leaking at the furnace Biggie Problem Solving | Owners Helping Owners 10 06-26-2011 04:32 PM
Water leaking from fridge Robert M Problem Solving | Owners Helping Owners 4 08-09-2006 07:07 PM
Gray Water Tank Leaking Legacy Posts Problem Solving | Owners Helping Owners 6 06-02-2003 10:04 PM
Leaking water inlet Legacy Posts Problem Solving | Owners Helping Owners 11 04-27-2003 09:02 AM
