Help, Casita sagging onto frame - Fiberglass RV
Old 11-11-2012, 10:43 AM   #1
jplumber's Avatar
My 1981 Casita the frame is breaking the fiberglass on 3 corners when I jump on the tongue you can see the frame go into the body. has anyone seen this before? When I look under the camper the frame looks fine but the body seems to be sagging. is this from a rotten floor or ?
jplumber is offline   Reply With Quote
Old 11-11-2012, 02:45 PM   #2
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Wow- sounds like whatever support was built in at those points is failing! I don't know enough about Casitas to venture an opinion as to why- What was the build year? Has it had water leaks, and if so, is there plywood reinforcement in the failing locations that might have rotted away????
Hope other Casita owners weigh in-
Francesca
Old 11-11-2012, 06:04 PM   #3
Originally Posted by jplumber View Post
...you can see the frame go into the body. has anyone seen this before? When I look under the camper the frame looks fine but the body seems to be sagging. is this from a rotten floor or ?
I am dealing with a similar problem in my Compact Jr's rebuild, but only in one rear corner under where the kitchen sink was. I suspect that un-noticed leaking plumbing may have contributed as the wood floor had a water stain. But that alone could not have cracked the fiberglass? I speculate that hitting a pot hole in the road jarred that area enough to crack the fiberglass, and not finding and addressing the initial crack allowed it to open up and settle around the frame.
Old 11-11-2012, 06:16 PM   #4
John in case you dont get the answer to your problem on this forum, & in case you havent seen it yet there is a Casita Travel Trailer Forum. You do need to register to read the forum though.
Old 11-11-2012, 06:51 PM   #5
jplumber's Avatar
Thanks I will try the casita forum. I know the windows leaked on this casita so maybe the wood is rotten. Looking under the trailer I don't know how it would attach its all fiberglass. I hope it is fixable
casita
Sagging Ensolite Dawn S Problem Solving | Owners Helping Owners 4 07-15-2009 01:54 PM
Casita Trailer Frame... BEWARE.. Phillip Modifications, Alterations and Updates 13 06-20-2009 08:51 AM
Sagging doors Rick kl Problem Solving | Owners Helping Owners 11 12-01-2008 05:13 PM
Casita Frame Problem d_wildemann Problem Solving | Owners Helping Owners 5 05-18-2008 07:51 PM
Help with a 13' Casita sagging in the rear Cliff in SAV Problem Solving | Owners Helping Owners 3 07-15-2006 11:39 PM
