Help...Door won't open! - Fiberglass RV
Old 08-23-2011, 04:41 PM   #1
Trailer: 1972 13' Boler
HELP!!! Just bought a 72 Boler 13. Parked it in the garage and all was fine, went to clean it up and I can NOT get the door to open. PO said never had that issue and that the key works. Key will turn, but door will not open. Pretty good door sag but seals well. My daughter may have been playing in there and locked it from the inside and then shut the door...would that do it? Worried I'll make things worse if I have to remove the hinges, but that is my only option at this point unless someone has a suggestion.
On a side note, any Boler owners near Springfield/Branson, MO?
Thanks!! Greg
gacole2000 is offline   Reply With Quote
Old 08-23-2011, 05:46 PM   #2
Greg H's Avatar
Trailer: 72 Boler American
Indiana
I don't know what to tell you, mine doesn't lock period.
Old 08-23-2011, 05:48 PM   #3
Well, I took the hinges off and sure enough, it was locked from the inside (note to self). However, now that I've got it put back together it will not open all the way and is very rough. Is there supposed to be a "bend" in those bolts? Suggestions to get it opening smoother? Thanks- Greg
Old 08-23-2011, 10:50 PM   #4
Trailer: 1972 Boler American
Montana
Mine locks fine from the outside but has nothing going as far as locking from the inside. Surely it must have at some point. Once we get this hinge fiasco sorted out, that may be the next puzzle to focus in on.
sara maccalman is offline   Reply With Quote
Old 08-24-2011, 06:27 AM   #5
Barrie Bochoff's Avatar
Trailer: 13 ft Trillium (sold 1/1/12)
New Brunswick
Door sag is not an uncommon problem with our eggs. After I bought mine one of my hinges broke. I took the opportunity to remove both hinges, fill the screw holes with fiberglass and re-drill and reposition the door when I installed the new hinges.
Barrie
Barrie Bochoff is offline   Reply With Quote
Old 08-24-2011, 08:01 AM   #6
LukeP's Avatar
Iowa
Don't think you'd want a bend in the bolt! You may have seen these at Scamp, but they're a cheap replacement Door Hinge Repair Kit (Brass Ball, Spring, Nut & Bolt)
Is your 1972 Boler, a Boler American, by chance?
LukeP is offline   Reply With Quote
Old 08-24-2011, 09:07 AM   #7
Montana
Just the question that was on my mind.
Old 08-25-2011, 04:57 AM   #8
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: gacole... You can order new door hinge pins, brass balls, tension springs and nuts from the parts store at Scamp trailers www.scamptrailers.com . That's where I got mine!!!
Old 08-25-2011, 09:16 AM   #9
Ordered those last night and I'm sure it will help. I've figured out what my door issue is (besides my daughter locking it from inside and closing the door). The lower hinge is tilted out towards the front of the trailer which makes the top left side of the door sag. It appears that the tops have been reinforced and the lowers have had some work done to them, but not properly. I'm think of getting some small stainless plates to sandwich the fiberglass and get the hinge straighten up and realign the holes...has anyone else tried this?
Door Flying open! Jonathan S. Care and Feeding of Molded Fiberglass Trailers 16 08-08-2008 06:59 PM
Door won't seal. carole sullivan Problem Solving | Owners Helping Owners 14 06-21-2007 12:02 AM
The open door james kent Modifications, Alterations and Updates 9 03-02-2007 09:15 PM
Keeping door open? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 06-05-2003 03:37 PM
