Help fitting 8ft Awning to 13 ft trailer - Page 2 - Fiberglass RV
Old 07-23-2012, 11:12 PM   #15
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Roy, to shorten the awning is a real possibility...I will look at it soon to see how this can be done. Good thought. The problem is rain water pooling up in the center of it if the fit is not taught. In the other thread that I read, the guy put an extra tension rod in the center. Also interesting idea. Thank you for responding.
D Davis is offline   Reply With Quote
Old 07-24-2012, 11:25 AM   #16
Trailer: Currently Shopping
Keys....
I just wanted to say thank you again, in regard to the "key" issue. Canadian Tire could not copy my only key, Home Hardware said "nope can't help you"...a locksmith said "don't have the number on the key, can't find a master blank for it...sorry"
Well, well, well, after three tries I give up, this is hopeless. On the advice of another member, I try the forth "key" place. Bingo, she finds the master blank, cuts the key in 2 minutes, and charges me 2.69!!!!! and it worked!
So, to everyone who did not mean to scare the hell out of me, but did...I say keep trying, most of the issues I found owning my new trailer, are not as bad as they would seem.
Donny
Donny55 is offline   Reply With Quote
awning
8ft awning wanted to fit Aer-Flo Alison Cape Breton Classified Archives 6 04-13-2011 03:36 PM
Air fitting to purge water lines? joelh Care and Feeding of Molded Fiberglass Trailers 4 11-07-2010 05:00 AM
Wanted 8ft trimline awning screen room or add a room Rob H Classified Archives 0 06-08-2010 09:35 PM
thoughtful engineering and fitting-out? Richard Davis Care and Feeding of Molded Fiberglass Trailers 13 08-08-2008 07:37 PM
Really crummy Scamp shower fitting Steven Tonnesen General Chat 15 02-13-2006 10:39 PM
