HELP -- I need to drill a 1 1/8" hole in fiberglass - Fiberglass RV
Old 12-04-2012, 10:19 AM   #1
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Would I use a
ID:	533241-1/8" Hole Saw ?
1 1/8" Wood bit ?
1 1/8" Steel drill bit ?
Step bit ?
Will be adding another 12 Volt socket
Old 12-04-2012, 10:25 AM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I'd use the hole saw or the step drill. Cover the area with masking tape first to get a cleaner edge. They make hole saws with finer teeth, which would make a nicer hole.
Old 12-04-2012, 11:17 AM   #3
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
I would use the hole saw with the masking tape as Tom suggested. Take it slow and let the tool do the work, you'll get a cleaner hole that way.
Spanke
Trilliums Rock!
Old 12-04-2012, 11:18 AM   #4
Trailer: 1975 Boler
I've used a fine-toothed hole saw and I wasn't happy with the amount of strands that got pulled up and gel coat chipping. The thing I was putting in the hole had a flange that covered the rough bits. I did not use masking tape either...that probably would have helped.
I would have liked to use a step-bit as it seems as it would have been 'gentler' and more gradual.
Evan Friesen is offline   Reply With Quote
Old 12-04-2012, 11:26 AM   #5
cpaharley2008's Avatar
I used the hole saw to install mine, keep speed slo tho.
Old 12-04-2012, 11:27 AM   #6
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
This would work nice and quick, but there would be a bit of fraying on the sides of the hole. You would get a bonus second hole too, maybe for an access hatch on the other side. * * *
* * * Please kids, do not try this at home, this is a job for a professional.
All kidding aside, the hole saw is the way to go. As long as it is sharp, it will work fine. Start slow until you get a good bite. Use a bit of sandpaper to smooth out the glass shards on the edge of the hole when done too.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 12-04-2012, 11:38 AM   #7
Hole saw
Drill the 1/4" pilot hole in forward , run the 1 1/8" hole saw in reverse .
Less chance of having a tooth catch and causing damage . Method works well on steel and aluminum siding
Old 12-04-2012, 12:12 PM   #8
Trailer: Scamp 19
Hole Saw
Use the hole saw, and not the butterfly bit. The hole saw cutting through the masking tape will cause less chipping of the gelcoat. Don't use the butterfly bit it will damage the glass, gelcoat, and you will have a rough hole. I haven't used the other tools, but alway had good luck with the hole saw on boats. Be careful not to cut through the interior covering as that won't work well. As others have said, take it slow and don't use a lot of pressure on the hole saw/drill motor as that will case some tearing of the glass strands. It is also not a bad idea to use tape on the interior of where you are drilling to help keep tearing on the inside of the hole to a minium. Good Luck
captsteve2002 is offline   Reply With Quote
Old 12-04-2012, 12:19 PM   #9
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I like the carbide grit hole saws. Failing that, the other Steve's suggestion of running the saw tooth hole saw backwards (after the pilot hole penetrates) is a good one.
When the saw penetrates be prepared for the teeth grabbing any carpeting, if any, that might be glued to the back.
Old 12-04-2012, 12:20 PM   #10
I'm sure this won't work in your situation, but if you can clamp a piece of wood to each side of where you are cutting the hole, it helps in making a cleaner cut. Or at least wood on the back side.
Old 12-04-2012, 01:39 PM   #11
I'm quite fond of the Dremel RotoZip for this type of thing. It makes the smoothest cut in fiberglass I've ever seen. To cut a round hole you would have to make the circle and follow it slowly.
I would think that a step bit would be the next best thing.
Old 12-04-2012, 01:44 PM   #12
Except one little ooops, your hole is now oblong, they cut too easy.
Old 12-04-2012, 02:33 PM   #13
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I have a side dinette with cabinets above. Thinking about adding the new 12 Volt outlet under the cabinet and between the shelf openings.
Need outlet for my laptop.
I also have a 120 volt outlet on the bench seat. I could add the 12 volt next to it.
Decisions Decisions
Old 12-04-2012, 03:03 PM   #14
Trailer:
Professionally, that's what we used building fiberglass yachts, if only because a toothed hole saw doesn't last long in fiberglass. But if we had a one-off to do, we would buy just a fine-tooth hole saw for economy.
Drilling into Fiberglass with a hole saw. WARNING freddo411 Problem Solving | Owners Helping Owners 8 05-05-2012 09:41 PM
Great way to fill a fiberglass hole Stacy Crotser Care and Feeding of Molded Fiberglass Trailers 16 10-14-2011 04:28 PM
SOLD: '75 "EL MACHO" 13' fiberglass (Boler clone) in California elmacho Classified Archives 3 10-28-2010 12:58 PM
2010 Custom Fiberglass teardrop"Real Kool" Dave Baston Referrals: Molded Fiberglass Trailers 1 06-07-2010 05:14 PM
INFO RE Fiberglass "Travel Lite" Trailers of Early 60s Don Cordier General Chat 4 07-23-2008 11:18 AM
» Trailer Showcase
Scamp
Carol B.
1985 Scamp
rojo
