HELP! I need Trillium Jubilee axle specs. - Fiberglass RV
Old 06-26-2017, 05:36 PM   #1
Trailer: Trillium Jubilee '79
Newfoundland
On day 3 of our 3 week summer holidays. Hit a pothole. Damaged the right side of axle. Wheel bent in at top, projecting out at bottom by 10-12 degrees. 1/2" clearance from side of well; not rubbing on housing. Bearings intact. Not hot after driving. Looking for specs on Trillium Jubilee's tortion axle. Need to order replacement. Any HELP greatly appreciated!!
Terranovafox is offline   Reply With Quote
Old 09-25-2017, 01:09 PM   #2
Trillium Jubilee
Did you ewer get the spec help you were looking for/ I own a Jubilee as well
bigEZbob is offline   Reply With Quote
Old 09-25-2017, 01:38 PM   #3
Newfoundland
Yes, I did. I have the spec sheets and contact info on separate sheets. I am unable to upload them for some reason. I can only get 1 sheet to download. Private Message ((PM)) me and I'd be happy to send them along. Had a new axle installed July 18. All in good working order.
Paul
Old 09-25-2017, 02:15 PM   #4
Newfoundland
Attempting to download the second axle spec sheet with the Jubilee actual measurements.
Old 09-25-2017, 02:23 PM   #5
Newfoundland
Both spec sheets downloaded separately. Address , province different for both. First, I received from David Tilston in a PM. The second, the one with the specs written on it, came from Atlantic Trailer from Donovan's Industrial Park, Mount Pearl, NL. Those are the Jubilee actual measurements.
Old 09-25-2017, 02:44 PM   #6
Newfoundland
Gonna try to post pictures.
Old 09-25-2017, 02:51 PM   #7
Newfoundland
The first 2 pictures show the damage (bend). The wheel was still turning and viable but not something you'd want to take any chances with. The 3rd picture shows a point on one side of the wheel where the axle is welded to the frame. I wet my finger and ran it along the weld to make it stand out. When the new axle was installed they welded it back. The 4th picture shows the new wheel, same side. The big thing was ensuring there was enough clearance between the top, front and back of the wheel well. Here, the trailer is empty.
Old 09-26-2017, 01:52 PM   #8
Newfoundland
In case others are wondering, here is the Picking Ticket from DEXTER for the axle shipped to NL for my Trillium Jubilee trailer.
Hope this is helpful to someone.
Old 09-26-2017, 03:24 PM   #9
Newfoundland
Pictures show weld views, brake plate, and alignment of the Torflex (from passenger side looking from the front toward the rear, the angle rises up 22.5 degrees.
axle, trillium
Trillium 4500 replacement axle, specs request Tyhee Problem Solving | Owners Helping Owners 14 05-27-2015 12:59 PM
Need Specs for Dexter #9 Axle for 1972 Boler 72Boler Modifications, Alterations and Updates 13 04-03-2015 09:08 AM
need propane heater for trillium jubilee verna crowell Problem Solving | Owners Helping Owners 2 11-02-2012 10:10 PM
Need Burro Window Specs Kelly G Problem Solving | Owners Helping Owners 3 05-25-2009 05:59 AM
Need help with 1979 Trillium Jubilee schowes Problem Solving | Owners Helping Owners 3 05-11-2008 09:38 PM
» Virginia Campgrounds
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
