Help! Interior cracks in fiberglass - Page 3 - Fiberglass RV
Old 05-16-2019, 07:21 PM   #41
John and Bill- U bolts! Good call- we will try that. So I suppose it’s an original frame then and before the recall. Some of the screw heads just rusted off as we tried to get them out lol so they must be fairly old. Tomorrow we are going to try and get it bolted and sorted, and back to it’s original solid shell! Thank you guys for helping me pin-point this major issue before it got worse. Couldn’t thank you more really, and hope to return the favor to the next new trillium owner.
Kortney M. is offline   Reply With Quote
Old 05-16-2019, 07:53 PM   #42
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Well I just did a quick search and found several threads mentioning the use of U bolts. One good suggestion is to use square shaped U bolts in order to eliminate stress on frame edges. Here are square U bolts at etrailer dot com:
https://www.etrailer.com/Boat-Traile...CABEgLLcPD_BwE
Old 05-16-2019, 09:24 PM   #43
Very helpful!! Thank you John 🙏
Old 05-17-2019, 03:24 PM   #44
Trailer: 2013 Escape 19
The frame recall didn’t replace the frame, it repaired it. Do a search via goggle and you will find out what to look for. It’s the forward bolts that were the problem. They were drilled through the frame just where it was bent (a weak spot). Lead to cracks and frame failures. After the recall the design was changed where the front bolts went into tabs instead of through the frame.
Old 05-18-2019, 04:14 AM   #45
Oh okay- I see. Thanks Bill. I will take a look for that.
spiderweb like cracks on fiberglass surface jondsw Care and Feeding of Molded Fiberglass Trailers 8 01-23-2023 10:35 AM
Small cracks and bubbling in fiberglass ostojo Care and Feeding of Molded Fiberglass Trailers 7 11-08-2012 08:34 PM
Repairing cracks in green fiberglass MadgeW Care and Feeding of Molded Fiberglass Trailers 15 03-06-2012 07:23 AM
Fiberglass cracks Janne Potter Problem Solving | Owners Helping Owners 3 04-25-2011 02:53 PM
How do you fix Fiberglass cracks SharonNDean Problem Solving | Owners Helping Owners 12 02-12-2008 09:46 PM
