Help! Lock broke on Campster back door - Fiberglass RV
Old 05-22-2009, 04:40 PM   #1
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
I have a regular entry lock on the back door of my Campster. It won't open. I took off the back knob and can turn everything with a screwdriver; lock still won't open. (It opened with difficulty yesterday at Cabela's when I loaded in two chairs and that was apparently its death knoll.)
Back sliding door window is locked.
Side windows have screens; could cut one but someone would have to be strong enough to get to the lock (which means moving a bunch of stuff stored in the way) and still small enough to go through the window. Not likely.
Pop top is locked down. (And has intact canvas.)
Any suggestions short of a locksmith? I'm going to google it but thought maybe one of you has had a similar problem. It's a push button lock, probably a Kwikset, keyed outside.
If you have any ideas, please email me: barbaram (at) csufresno.edu as I'm not on the web but can read email on my cell phone.
Bobbie
Old 05-23-2009, 11:41 AM   #2
james kent's Avatar
Trailer: Boler 1984
Just a thought.....
Try placing two putty knives in the crack and then wedge them apart with a wide screwdriver. It may be enough to pop the door open without damaging the door or the side.
Old 05-23-2009, 01:41 PM   #3
Dan Meyer's Avatar
Push (or pull) the door like you are trying to close it further, then try to pop the latch.
-- Dan Meyer
Old 05-23-2009, 01:42 PM   #4
There isn't really a crack. The door overlaps the frame. Here are a couple of pictures.
Old 05-23-2009, 05:17 PM   #5
james kent's Avatar
Trailer: Boler 1984
Attachment 20428
To the left of the assembly I can see a bolt head. If you remove these would the whole door and frame come off?
In the centre of your latch there is a small piece, at the end of the slot, holding the centre tube section in place. If you depress this will it let the centre push into the trailer and maybe release the latchbar?
Old 05-23-2009, 06:05 PM   #6
Attachment 20428
To the second, no. To the first, yes, and I didn't have to remove the whole frame, just loosen the left side. It will now need resealing but the lock is gone (no latch at all until I replace it.)
Bobbie
Old 05-23-2009, 06:09 PM   #7
peterh's Avatar
If your Campster is built about the same way our Scamp and Surfside are, your door opens outward and the hinges are outside, too. If that's the case you could try pulling the hinge pins and pull the door off that way.
Old 05-23-2009, 06:13 PM   #8
The hinges were sealed (both ends capped.) That was my first idea.
I'm inclined to put just a door knob that won't lock on it now, and then put a keyed latch outside, and a lock inside.
campster
Query about door lock to lock from inside sara maccalman Problem Solving | Owners Helping Owners 4 11-14-2010 07:11 AM
Door Lock Paul Richter Problem Solving | Owners Helping Owners 0 05-18-2010 10:30 AM
Help needed for Campster lock and propane regulator Bobbie Mayer Problem Solving | Owners Helping Owners 11 06-09-2009 06:44 AM
I love that back door on my Campster... Bobbie Mayer General Chat 0 11-12-2008 09:30 AM
Next problem... Hinge on outside door broke off!! Rob Carmody Problem Solving | Owners Helping Owners 6 09-07-2008 06:40 PM
