Help, locked out in campground - Fiberglass RV
Old 09-21-2015, 05:16 PM   #1
courtney's Avatar
Trailer: 1982 13ft Scamp purchased on May 2nd
My six year old has locked us out of our '82 Scamp. Everything, including car keys are in there. Locksmith is two hour wait and $80. Tips?
courtney is offline   Reply With Quote
Old 09-21-2015, 05:17 PM   #2
Your not the first to do that.. can u remove hinges?
Old 09-21-2015, 05:21 PM   #3
You should be able to remove the door handle with two Phillips screws on the outside and turn the square shaft inside with the blade of a flat screwdriver (or maybe even with the door handle itself by rotating the whole handle and base after you remove the screws).
It won't work if the locking pin is in place on the inside.
Old 09-21-2015, 05:30 PM   #4
courtney's Avatar
The pen couldn't get put in and lock us out can it? Thought you could only do that from inside?
Old 09-21-2015, 05:30 PM   #5
I'm not above locking myself out of cars or campers so they all have a hide-a-key somewhere. I also carry a lock out tool for others to use. Of no use to you now, but something to consider. Is there a slider window to shove the kid through to unlock the door. Or screws to remove a window.
Old 09-21-2015, 05:37 PM   #6
You could insert the pin and then slam the door closed, yes. It's loose enough that there's a good chance it would fall out, but I recall another forum member got locked out with the pin in place. I believe they had to remove the whole door. I'd try windows before I did that.
Old 09-21-2015, 05:38 PM   #7
courtney's Avatar
Crap. So even if the locksmith comes, we might not be able to get in?
Old 09-21-2015, 05:44 PM   #8
So I take it the pin is in place and the windows are locked…
Okay, how about this… remove the handle, insert a bent wire through the square shaft opening, and try to dislodge the pin.
Old 09-21-2015, 05:51 PM   #9
courtney's Avatar
Got the screws out. when a twist the handle to open, all it does is wiggle the handle with the base. Is there something else I need to do?
Old 09-21-2015, 05:51 PM   #10
courtney's Avatar
Rectangular base spins freely. Handle still locked.
Old 09-21-2015, 05:59 PM   #11
courtney's Avatar
Ok, got someone to help me take the door off and need to get it back on now. We're there two of those ball thingies on top of each hinge? It's dark, and can only find one!
Old 09-21-2015, 06:01 PM   #12
I forgot about Scamps inside lock pin. Hide-a-key would be of no value in this case. I did help get into a locked camper by removing the handle screws as Jon says.
Old 09-21-2015, 06:03 PM   #13
So you can put the square shaft into the square opening and turn the whole handle, base, and shaft freely, but nothing happens?
I'm concerned because if the square opening turns, the latch should release. If the square opening won't turn, that's because the pin is blocking it. I'm wondering if something has gone amiss with the inside part of the latch mechanism. And if that's the case, the next time you close the door for any reason, you'll be in the same situation.
Let us know what you figure out… I am very curious!
Old 09-21-2015, 06:12 PM   #14
Here's what the hinge should look like:
Name:   ImageUploadedByFiberglass RV1442880696.050723.jpg
Sure hope it's not raining where you are, too!
When it's cold out and you're sitting out, how do you keep warm? rgrugg General Chat 40 02-22-2012 07:56 PM
Can you help us check out a trailer? Penney H. & Mike E. Problem Solving | Owners Helping Owners 0 08-17-2007 06:07 PM
old topic locked CharlynnT Jokes, Stories & Tall Tales 1 09-26-2006 12:11 AM
