Help! My "no-leaks" Scamp had a leak - Fiberglass RV
Old 03-07-2016, 12:59 PM   #1
Hi Friends,
I have read no less than 30 threads on leaks, cried twice and said some 4-letter words. Now I'm coming to you kind and wise people for help.
When doing a deep clean of my new-to-me 2002 13' scamp, I noticed some blue-green mildew on the back side of my front bench seat where the MDF board meets the front wall(photo1). Note that the bench is a previous owner modification. This trailer never had the standard front Fiberglas bench. I pulled the MDF bench and found a section of moist, mildewed headliner and carpet (photo2). I cut that section out, am running fans and dehumidifier (photo3). I will bleach it next. I found the source of the leak (gap in plexiglass seal) and I know how to address that. I also suspect a leaky rivet in the kitchenette and I know how to deal with that from the outside.
Here are my questions:
1) what happens to unseen moisture trapped between insulation and fiberglass? I suspect there was/is moisture between the window and the floor in the section of headliner that I have not cut out yet. I don't feel wetness on the remaining headliner.
2) how much deeper do I dig for more moisture? If I pull up six inches of insulation and headliner and don't feel more moisturizer, is that a good stopping place?
Any input and suggestions greatly appreciated.
Name:	ImageUploadedByFiberglass RV1457380226.969505.jpg
Name:	ImageUploadedByFiberglass RV1457380241.379732.jpg
Name:	ImageUploadedByFiberglass RV1457380260.605224.jpg
Ruralredhead is offline   Reply With Quote
Old 03-07-2016, 01:46 PM   #2
We had a leek in our 5r and didn't find it until we were camping and the person that was sleeping on the dinning/made into a bed thing had water dripping from the overhead antenna. Would have not found it if it wasn't for that incident in the rain.
The water had dripped on the table when it was in place and ran to the back side of the camper and moved along the floor to the curb side. The antenna was on the opposite side of the camper. Water leaks are really hard to find.
Old 03-07-2016, 03:09 PM   #3
None
You may be fine with what you have found.
This is just conjecture on my part, but it seems that gravity would work for you to pull any moisture down, until it got stopped by the bench and floor.
I'm sure other folks with a lot more experience than me will be along to either confirm or dispute my conjecture.
Good luck.
LyleB is offline   Reply With Quote
Old 03-07-2016, 03:24 PM   #4
Name: Frederick / Janis
Trailer: Previously Scamp 13 2002,2016. Scamp 16 on order
Front window leaks are fairly common in anything over 5 years of age. If it were mine, I would dig deeper and re-do the front window while I was at it. Our 2002 came with a leak in the back area. Previous owner did some "flooring" which was a cover up without actually finding the leak.
Ended up removing all the re-done flooring and trashing it anyhow. Turned out to be a belly band leak which could only have been found by opening up the rat fur and pulling back the bubble wrap. Found the leak not only sight, (black streak) but confirmed by watching water enter during a heavy rain down pour. Once fixed, treated everything good with mildew/mold treatments. Spray glued the bubble wrap and rat fur back into place. Easy as can be and invisible that anyone had worked in that area.
bpfick is offline   Reply With Quote
Old 03-07-2016, 04:18 PM   #5
Trailer: 77 Scamp 13
Only makes sense to test that front window and door for leaks while you have everything cleared out.
Yes I said door. That little bugger can run down, hit the lip for the seat and run all the way around to the front before dripping off to the floor. Or a top seal leak can drip right onto that couch area. Don't ask how I know.
Can do a bulk hose test I would do a section at a time with that. If you get any water coming through switch to a watering can and test smaller areas until you narrow down the location to dig for.
Hinge side of door, belly band to the window, curb and street side of window, belly band around to the end of the couch/bench. Hit an area with water, then wait and give it time to work its way down before moving on to next section.
On drying out all water flows downhill so given a bit of time the moisture will all tend to end up out of there and on the floor. If you can slide a thin flexible wand up behind the wall covering any place it might speed up the process of getting moisture out. Doubt it is needed though.
You can sprinkle or blow baby powder or talc around the edge against the wall, any trace of moisture even a seepage will discolor it. Little bit of a hassle to vacuum up so I would do this only if I suspected a tiny leak that I was having trouble spotting. Focus the powder in that small area. I know you don't want to deal with cleaning up a bunch or really wet baby powder. But we used to use it to track down small oil leaks on motorcycle engines. And I have used it in the scamp for same purpose.
Air flow and dehumidifier are probably doing the deed just fine.
Old 03-08-2016, 09:40 AM   #6
Kansas
i've found that my door leaks, too. is replacing the D-shape weather stripping a good idea for a first attempt to fix it??
lrb945 is offline   Reply With Quote
leaks, scamp
Anyone had their trillium or Boler "Vehicle wrapped" MoDZuKi Modifications, Alterations and Updates 18 12-07-2015 12:04 AM
I had a beautiful '72 Trillum...for 15 minutes! Help? Lori Colin Problem Solving | Owners Helping Owners 13 07-27-2015 02:46 PM
Help with leaks earnie Problem Solving | Owners Helping Owners 6 09-19-2010 02:20 PM
Trailer leaks are making my eyes leak Amy M Problem Solving | Owners Helping Owners 9 06-03-2010 10:10 PM
Once had a battery, starting over, help sought Gigi Problem Solving | Owners Helping Owners 5 05-31-2006 07:36 AM
