Help! My Windows Are Leaking! - Page 2 - Fiberglass RV
Old 05-06-2012, 01:36 PM   #15
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
I've posted this before but if you haven't replaced the rubber gaskets or injected something into the separations at the mitres, try this. Take some butyl putty (mine was just trimmings from rebedding a fridge vent), Stuff the stuff right in the gaps at the mitres. You may want to take a q-tip and some Windex and clean those gaps of dust and grit to assure some adhesion before "stuffing". Keep pressing until it more or less conforms to the shape of the gaskets. Take a black MagicMarker and "paint" it to match the gasket. I think you have already cleaned the freeing ports in the sliding window channel. In a heavy rain, sheets of water on the glass will not be able to run thru those separations wholesale and the freeing ports will be able to keep up. I know this isn't very elegant but sometimes interim solutions can function for a very long interim. I think you will find that the replacement gasket will, in time, shrink just as much as the one replaced so this fix is worth some thought.
jack
Old 05-06-2012, 05:41 PM   #16
Perry J's Avatar
Trailer: 16' Casita
Use Butyl tape. An RV store or building supply will have it. Don't use silicone. Use the search function to read the horror stories. Raz
You are recommending butyl tape between the glass and the frame when a window breaks and you simply replace the pane of glass?
Old 05-06-2012, 05:56 PM   #17
Raz
Raz's Avatar
Vermont
No, between the window and the trailer. Sorry if I didn't make that clear. Raz
Old 05-06-2012, 06:25 PM   #18
Laura, if you think it's leaking in the areas where the window glaze bead has shrunk, your choices are either to replace the bead or fill those areas. If you're looking to fill the cracks, maybe use this... and yes, I know it's silicone, but you're not putting on the body: Loctite 37460 3 oz Black RTV Silicone I used it to fill the gap in the gasket and lockstrip on my Scamp.
Or if you want to change the bead, maybe check here at the bottom of the page: Interstate RV Metal & Supply
windows
Leaking windows Hélène L Problem Solving | Owners Helping Owners 4 02-17-2009 05:51 PM
Leaking windows? Lenna F Problem Solving | Owners Helping Owners 3 09-20-2007 02:36 PM
Leaking windows Stephen Brown Problem Solving | Owners Helping Owners 29 08-04-2007 02:31 PM
Leaking windows GrahamD Problem Solving | Owners Helping Owners 1 07-15-2006 05:39 PM
leaking windows Legacy Posts Problem Solving | Owners Helping Owners 32 12-19-2002 04:38 AM
