so i pulled out the bulbs in the trailer and they all read 1141. is this the same as 1156 or is the same as 1142?
If you're talking about the interior lamps, the 1141 would be similar to the 1156. Single "bump" on the bottom, and the side tabs align directly opposite each other. Just an [b]on/off type bulb.
1142 would be similar to 1157. Two "bumps" on the bottom, and the side tabs are offset [b]
so it will not fit into an 1141/1156 socket. This is a [b]High/Low/Off type bulb.
