Help on instal of Fantastic Fan in 13' Boler - Fiberglass RV
Old 05-21-2008, 08:42 PM   #1
Pat C's Avatar
Trailer: 1981 Boler 13 ft / 2005 Dodge Caravan
We had Fan Tastic Fan 6600 installed in our 1981 13' BolerTrailer. The installer could not fit the plastic surround inside the trailer....Has anyone else had this problem and how did you solve it...Thanks for any info you can provide....Pat.
Pat C is offline   Reply With Quote
Old 05-21-2008, 08:49 PM   #2
Chester Taje's Avatar
I built a wood frame on the inside, then installed plastic surround inside trailer.
Old 05-21-2008, 08:55 PM   #3
Pat C's Avatar
I figured we would have to build a wood frame but why did you still need the plastic surround? Did you cut down the original plastic provided with the unit?....I am clueless about these kinds of things.
Old 05-21-2008, 09:14 PM   #4
The wood frame was basically just a spacer. Yes i then cut down the plastic surround to size i needed.
Old 05-21-2008, 09:20 PM   #5
Trailer: Fiber Stream
Talking
I did the same thing.
Old 05-21-2008, 10:13 PM   #6
Pat C's Avatar
Thanks for the input.The picture was great....I don't expect we should have any problem now...Pat.
Old 05-21-2008, 11:06 PM   #7
Pete Dumbleton's Avatar
I cut down the plastic frame then built a wood edge for it to sort of match the rear hatch frame. Could have avoided it by getting the higher profile fan (more outside and less inside for thin-roofed RVs).
boler
fantastic or non fantastic? Flygal General Chat 16 04-07-2010 09:53 PM
Fantastic Fan spacer installation on top of a Boler kevin61 Modifications, Alterations and Updates 1 07-05-2009 05:55 PM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
Fantastic Fan Roger Harshaw Problem Solving | Owners Helping Owners 4 03-15-2008 12:47 AM
Fantastic fan/vent in a boler.Danger??? colin k Modifications, Alterations and Updates 15 07-11-2006 01:36 PM
