Help! removing decal from back Scamp window - Fiberglass RV
Old 09-06-2016, 06:14 AM   #1
Hi All,
There is a Skull & Crossbones decal on the back window of my project Scamp. Since I am not a Skull & Crossbones sort of gal, I've tried to remove it. So, far I've used soapy water, vinegar, WD-40, with no success. I'm concerned about damaging the window since it's not glass.
Any suggestions on how to remove the darn thing!?!
Thanks!
Tonnie is offline   Reply With Quote
Old 09-06-2016, 06:47 AM   #2
Trailer: 2013 Escape 19
I just removed all the faded out decals on my Casita. The trick for me was peeling a corner just enough I could grab it with a needle nose pliers then pull it up.
On glass I would use some heat first. Once it is off, WD40 should clean up the residue.
Old 09-06-2016, 06:59 AM   #3
Thanks Bill...
It sounds like you're talking about removing the decals from the outer fiberglass shell.
My challenge is attached to the back window of the Scamp which is plexiglass or some kind of acrylic.
Old 09-06-2016, 07:08 AM   #4
Surprised window isn't glass. Still the fingernail trick should work. Get a corner up, doesn't take much, grab it with needle nose pliers and start peeling.
Old 09-06-2016, 07:22 AM   #5
Trailer: Bigfoot B-17 CB
Heating it might help. A hairdryer set on low heat will loosen some adhesives. Careful. Too much heat could damage the window.
Jack L is online now   Reply With Quote
Old 09-06-2016, 07:45 AM   #6
Trailer: 2005 Scamp 16
I have heard that using something like olive oil, soaking the sticker and letting it sit, and then using a plastic credit card could work. Good luck!
emij is offline   Reply With Quote
Old 09-06-2016, 08:37 AM   #7
Have had good success with using a hairdryer as well. Heat up the whole decal well.
Once you have a corner lifted keep using the hairdryer on it and pull it off nice and slow and steady and evenly and you will have a better chance of a lot of the adhesive coming off with it at the same time.
Old 09-06-2016, 09:11 AM   #8
A raiser blade in a holder.
Old 09-06-2016, 10:18 AM   #9
Name: Steve and Carolyn
Trailer: Casita 17" SDX
Hot Towel and Steam
Hi-I removed decals off a brand new truck with no problem. Steam. I used a clothing steam gun. Hot steam does the trick, Wear gloves,long sleeves and closed shoes. Those are all precautions with live steam.
If you use the steam on your clothing burning the material, the plexi or acrylic will hold up.
Goo-gone or something at your hardware store will remove the stick stuff.
Carolyn and Steve is offline   Reply With Quote
Old 09-06-2016, 01:57 PM   #10
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Maybe you mean a razor blade. Heat will help on vinyl decals. Paper ones will tear easily.
Old 09-06-2016, 02:26 PM   #11
Thanks to all who have chimed in!
Well, I'll give all these ideas a try.
I have tried the hair dryer before unsuccessfully.
It seems like it would be an easy thing to do, but I'm sure not getting anywhere. Maybe I'm being too gentle because I don't want to mar the window.
Where there's the will, there's a way!
Old 09-06-2016, 02:49 PM   #12
I used a razor blade to remove a sticker from my enamel stove cover, and peeled some paint off with it. Now I need to find a sticker to cover it.
Old 09-06-2016, 02:58 PM   #13
Skull & Crossbones GONE!
Hi All,
The cannola oil and gentle pressure with the razor blade worked. There is still some adhesive and I'll get some Goo Gone for that. I had been afraid to use the blade so I was very, very gentle.
THANKS!!!!
Old 09-06-2016, 03:00 PM   #14
Oh, No! That's not good... That's why I'm so leery to use one on acrylic.
scamp, vin
Trillium 4500 Back escape window repair help everc04 Parts: Buy | Sell | Trade 1 06-25-2014 11:09 PM
Scamp back window and maxxair window vent SharonM Problem Solving | Owners Helping Owners 3 04-19-2013 11:06 PM
removing lights from top back of trillium Art LC Problem Solving | Owners Helping Owners 8 04-16-2012 11:59 PM
1976 "Scamp" decal size advice please Mike L. Problem Solving | Owners Helping Owners 3 06-25-2011 12:17 PM
Removing residual decal/trim markings adimiro Problem Solving | Owners Helping Owners 3 11-15-2006 02:59 PM
