Originally Posted by Infogypsy
And second, does one put water into the toilet (using fill press with marine toilet) before or after using toilet?
Before. Most toilets have a hand-held sprayer (just like a cheap kitchen sink sprayer) to help waste wash down when flushing, rather than adding a bunch more precious water.
Originally Posted by Eddie Longest
Before moving from the campsite with all water pressure off, flush the toilet so no water is in the bowl prior to moving the trailer.
Really? I leave some water in the bowl - it helps the seal, and there little enough that it isn't a problem splashing around.
