Help with Bigfoot rear window install - Fiberglass RV
Old 08-11-2019, 12:04 PM   #1
Trailer: bigfoot
Saskatchewan
Hi all,
Can anyone tell me whether there is a top and bottom on the rear window of a 1981 Bigfoot? We took it out to reseal it and now I'm unsure which way up it goes. There is a "tempered safety glass" logo on the window, which seems like it should be the right way up (all the other ones are)... But then the joint in the frame would be at the top, which doesn't seem right as it's a definite weak spot for leaks.
Please help!Click image for larger version
spartacus is offline   Reply With Quote
Old 08-11-2019, 12:27 PM   #2
Trailer: bigfoot
Saskatchewan
Also, this is the only window which doesn't have a 'drain' cut into the bottom...
Old 08-11-2019, 03:22 PM   #3
It might help to look at the inside flange and window and study the screw holes to get the window and flange properly oriented.
Old 08-11-2019, 03:59 PM   #4
Trailer: bigfoot
Saskatchewan
Thanks! I'm positive that the inside flange had the joint at the bottom, so I'll go with that. Which puts the logo upside down, but I'm more comfortable with the seam on the bottom.
Old 08-11-2019, 04:31 PM   #5
There should be some evidence of where the screws threaded into the window frame and the holes in the flange should match up with the window.
Old 08-11-2019, 04:36 PM   #6
Trailer: bigfoot
Saskatchewan
Thanks. The flange does match up to the window, but there is no evidence in/on the trailer at all. I could install them either way up just as easily.
Old 08-15-2019, 08:51 PM   #7
AnotherCanadian's Avatar
Trailer: Bigfoot 17ft 1983
My 17ft Bigfoot is a 1983 and rear window has frame joint on bottom.
I just resealed it with 3m 4200 and was very careful marking orientation when removing so I didn't mess up installing as the 4200 is a fairly strong adhesive.
AnotherCanadian is offline   Reply With Quote
bigfoot
replacement window glazing for rear window on 1975 scamp Josh Wink Problem Solving | Owners Helping Owners 6 07-15-2016 04:05 AM
window gravel guard on rear window too?? summer scamp Modifications, Alterations and Updates 6 04-05-2015 06:50 PM
Need help with a Maxxair window vent install on a Scamp Carol H Problem Solving | Owners Helping Owners 13 11-02-2010 02:50 PM
Budget rear window a/c install Phil Underwood Modifications, Alterations and Updates 7 10-10-2007 07:09 AM
front and rear window install JIMZ Problem Solving | Owners Helping Owners 1 04-19-2006 08:02 AM
