I am trying to reinstall my 1980 13ft
boler door with the original hinges and
scamp replacement ball and bolts. I am using the original hinge location on the door but filled in the holes on the body. Upon lining up the door and hinges, I drilled new holes in the body but the door will now only open about halfway at which point there is a lot of resistance on the hinges of the body. I dont want to push it and crack the
fiberglass. I tried moving the hinges on the body (new holes) and it seemed to make it worse and the brass balls are not staying in their track. Is there a trick to this?? The door itself fits pretty well to the body when closed with not much gap. Any help would be much appreciated!!
