Help with Fuses and circuits - Page 2 - Fiberglass RV
Old 10-16-2016, 06:45 PM   #15
Trailer: 1997 16' Scamp
Another thought, most all wire you will find is stranded which stands up to vibration better and is more flexible. Romex house wire is solid.
varmint is offline   Reply With Quote
Old 10-19-2016, 07:22 AM   #16
Please let me know how this converter works for you! I have been debating buying the exact same one. My old one suffered after a power surge and I am still debating if I buy this or put in a breaker panel, battery charger and fuse panel instead.
Originally Posted by LionelAucoin View Post
This is what I purchased:
https://www.amazon.ca/WFCO-WF8735PB-.../dp/B004LF14Q4
I can't say I did an amazing amount of research or anything, but it had what I needed (and more) and would fit in the space that I had. :-)
TimR is offline   Reply With Quote
Old 10-19-2016, 07:32 AM   #17
Trailer: 1976 Trillium 1300 pulled by a 2015 Jeep Rubicon Unlimited
Will do! I am hoping to finish up with the wiring/install this weekend but unfortunately with the cold weather coming in it will be next spring before we get to take it out.
And will be posting pictures as I go on our blog: ourtrillium.wordpress.com
LionelAucoin is offline   Reply With Quote
Old 10-19-2016, 12:00 PM   #18
Very cool. I found the converter kind of strange though that going from black to brown costs more than double??!!
Old 10-20-2016, 05:29 PM   #19
Joe MacDonald's Avatar
if you already have a converter with ac and dc circuits whether fuses and or breakers, it is not usually too big a chore to pull out the dc section of the old converter, and wire in a new PD9130 or something similar, that is what I did, when I pulled the old converter out the dc section was just bolted on the back of the panel. I pulled it off, made a couple of brackets and mounted the new converter on the old panel. Ran a couple new wires into the panel, re did the wires for the battery, and bob's your uncle back in busines with a minimum of wiring
Joe
-1+
Old 10-20-2016, 06:58 PM   #20
Carl V's Avatar
Trailer: 1981 Trillium 5500
Quebec
I just bought a new Progressive Dynamics PD4135 for my trailer.
I haven't installed it yet due to lack of time (and now it's getting colder...)
My plan was to initially go with a deck-mount converter like the PD9130, and use the existing circuit breakers and fuses (or install a new DC fuse panel and new push-button AC breakers).
Then I realized that going with a all-in-one converter like the PD4135 wasn't more expansive, was simpler to wire and install, and offered the option to upgrade the trailer from 15A to 30A AC service, which I'm planning to do (not that I will be using 30A regularly, but I'll have the option).
The main thing on upgrading to 30A is simply getting a 30A main breaker instead of 15A, and replace the power cord to a 30A-rated, 10AWG RV cord. I found a 30A RV extension cord at Costco for $42 (real cheap) that I will be using for this.
My new converter has 6 DC and 5 AC branches. I'm adding both AC and DC voltmeters/amp meters, USB charging ports, new LED lights, new battery, and various switches to control all of this.
Carl V is online now   Reply With Quote
15 amp vs 20 amp circuits? LionelAucoin Modifications, Alterations and Updates 21 09-09-2016 07:13 PM
Blowing fuses and receptacle question.. Bluebamboo Electrical | Charging, Systems, Solar and Generators 19 05-29-2013 03:52 PM
Fuses in a Town and Country Tow Vehicle GingerB Towing, Hitching, Axles and Running Gear 21 12-28-2012 12:18 PM
Road racing circuits TonyB Camping, Campout Reports 3 09-04-2007 12:26 PM
The fastest fuses blower Legacy Posts General Chat 8 07-04-2003 02:36 PM
