Help with insulation tape??. - Fiberglass RV
Old 02-05-2013, 01:37 PM   #1
Chita's Avatar
Trailer: Scamp 13' 77 (:
Nevada
So I was really happy with my results so far... However....
The tape I used between the insulation came out...
I went back to Home Depot and could not find anything to use. What can I use to tape or glue the edges between the insulation? Please, I really want to put it back together, but this is holding me back now. I hate to see her like this...
Chita is offline   Reply With Quote
Old 02-05-2013, 02:25 PM   #2
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Am I looking at painted Ensolite on the walls?
If so, you might consider filling those gaps with painter's caulk, which dries to a similar "firmness". Painting over it once it cures would give you a virtually seamless look.
Francesca
Old 02-05-2013, 02:37 PM   #3
Francesca gave you some good advice. If you take a wadded up damp paper towel, you can stiple the caulk to match the ensolite.... by smushing it against the damp caulk.
Old 02-05-2013, 05:57 PM   #4
Ian-Vicki's Avatar
Name: Ian or Vicki
Trailer: 17 ft Burro Widebody / 2007 Explorer Sport Trac
smush?
Ian-Vicki is offline   Reply With Quote
Old 02-05-2013, 06:13 PM   #5
yeah, like smash... only smooosh or smush
Old 02-05-2013, 06:25 PM   #6
Some folks just don't Talk Tech, I guess...
"Smush" is an insider's acronym meaning:
to dab with a slow, methodical, understated, stern hand.
Feel free to ask more questions....
Francesca
Old 02-06-2013, 12:48 AM   #7
Chita's Avatar
Nevada
Thank you. I actually was thinking about using painter's caulk. However, when I went to Home Depot they had like 1000 different ones. Which one is the one I should look for?
Old 02-06-2013, 10:41 AM   #8
Before you go filling those seams I would think hard on any extra wiring you may need. things like overhead lights and a powered fan. Hot melt glue the 12 volt wires in and then fill the seam.
stevebaz is online now   Reply With Quote
Old 02-06-2013, 11:37 AM   #9
Just plain ordinary house brand painter's caulk will do. It's water soluble when fresh and I usually work with a washrag in one hand to correct drips/bumps while I go along.
Side note:
( As a matter of fact, so long as the label says it's paintable you could use any latex caulk at all...this could be a good way to get rid of any you bought for trailer-sealing use before we all came down with both feet about using it instead of butyl putty!)
Do take care to build it up in coats/layers, as directed on labels- if you apply it too thickly all at once it doesn't cure well and may produce cracking.
Donna's stippling idea is a good one- I'd do that as a finish coat once the seams are level with the surrounding Ensolite. On that subject, if I was trying for a totally seamless look, I'd probably use a razor blade to bevel the Ensolite edges some. Idea being to provide a level plane, at least in the most visible areas. But I'm compulsive in the painting-prep department!
Francesca
Old 02-07-2013, 01:10 PM   #10
Trailer: 1973 Love Bug '13
I agree with Francesca about trimming away a tiny bit of the old edge. Not only to bevel but to insure a fresh clean edge. I would also tape the edges of the ensolite to keep the caulk from going where you don't want it to go.
Let us know how it goes,
Cat futrell is offline   Reply With Quote
insulation Hazel in Sk Problem Solving | Owners Helping Owners 9 07-15-2012 08:43 AM
Insulation Brian Tin Problem Solving | Owners Helping Owners 12 11-02-2010 08:02 PM
Insulation Rick T Problem Solving | Owners Helping Owners 8 03-22-2009 06:56 AM
Casita Insulation ?? Jimmy M. Care and Feeding of Molded Fiberglass Trailers 6 09-14-2008 06:36 PM
Insulation Willie Brown Ft. Langley B.C. Rallies 0 12-31-1969 07:00 PM
