Help with rivets size - Fiberglass RV
Old 02-06-2017, 08:41 AM   #1
Does anybody know what size rivets I need for the porch light? I need to put a new one on.
Thanks
Robo Dad is offline   Reply With Quote
Old 02-06-2017, 08:45 AM   #2
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
You can use a drill bit to determine the size of a rivet. It should fit very snug in the hole.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 02-06-2017, 10:27 AM   #3
Trailer: 2008 Casita 17 SD
1/8" Dia. X 1/2" L.
Standard aluminum pop-rivets that you can get at any hardware or big box store.
Be sure to put some sealant in the holes before inserting and squeezing the rivets to seal them well against water intrusion. You won't need Snap Caps because they are riveted inside under the lens.
Old 02-06-2017, 11:16 AM   #4
Originally Posted by Casita Greg View Post
1/8" Dia. X 1/2" L.
If you go to a hardware store, True Value, Ace, Do-it-best types of chains that have all those bins of individually sold nuts and bolts you should be able to find in that section of the store some 1/8" Dia x 1/2" L stainless steel pop rivets with a solid pin. I can pull that size of stainless rivet with a hand operated rivet puller. The stainless rivets have a greater strength than the aluminum rivets. You will also find in that by-the-piece bin area the small rubber washers to use with pull rivets. I have been getting mine at my local Do-It-Best hardware store.
Old 02-06-2017, 12:40 PM   #5
Why would you need to buy more expensive stainless steel rivets for something like this? They're only going to be holding a plastic light that maybe weighs a couple of ounces.
Old 02-07-2017, 04:49 AM   #6
Borrego Dave's Avatar
SS rivets have their place, but using them for items with a thin plastic base build like the OP wants to install is just asking for cracking the plastic before the rivet pops. Can even happen with aluminum rivets once in a while.....oops.
Old 02-07-2017, 06:54 AM   #7
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
Furthermore, SS rivets are harder to drill out if the item they are holding ever needs to be replaced. And aluminum doesn't rust, which I would think would be the reason one would use SS in the first place.
Old 02-08-2017, 09:40 AM   #8
Thanks for all the advice, mischief has been managed!
Size of fridge vs size of opening... Uncle Cereal Problem Solving | Owners Helping Owners 3 01-11-2016 06:25 PM
Scamp Full Size Bed = Smaller Table Size TomK General Chat 49 10-03-2015 01:17 PM
HELP! At trailer hitch place, what size ball do I need? joy mccalla Towing, Hitching, Axles and Running Gear 5 01-18-2010 09:48 PM
Need some help, ball size & towing Arline Lovell Towing, Hitching, Axles and Running Gear 10 06-08-2008 02:59 PM
