Help with rotten Boler door - Fiberglass RV
Old 11-20-2007, 05:12 PM   #1
Trailer: Boler
Hi, we just bought a boler to fix up (after being inspired by this forum). Didn't even know what a Boler was in the spring!
Anyway just looking for ideas. Started with our door bowing out at the bottom. We bought rods to bring it in like the guy did with the Tank. I then noticed, when I took off the door handle to clean, that the wood was completely soaked and rotten. We cut off the inside layer of fibreglass and all the wood inside the door fell out in a rotten heap along with some water! (brought the door in a few inches at least). We were going to put wood back in the door and had a strip in the bottom but when we went out this morning both edges inside were wet and so was the new piece of wood. We took off the window frame inside and the area around window is dry so we have no iea where the water is coming in.
We were thinking of putting in the pink styrofaom insulation between the fibreglass- in case it leaks again. We think the bolts that have to go through the door to hold the rods will be ok as the fibreglass shell will still be there on either side of the styrofaom. Any thoughts?
We also have new hinges to put in but will have to make new holes as they don't fully align and the old holes aren't snug anymore. We were going to patch the holes with Bondo-Glass, will that work to re-drill the holes through?
tried to post a pic but it didn't show up on the preview.
LindaR is offline   Reply With Quote
Old 11-20-2007, 05:24 PM   #2
Trailer: Boler
here's the door- guess my first try the pic was too big
Old 11-20-2007, 07:56 PM   #3
Alf S.'s Avatar
Hi: I just re hung the door on our Boler and I used Tech Steel to fill the holes...wks like a charm. I bought it at a local auto parts store. It's just like plastiseen only it is an epoxy that you blend by kneeding it then press it into the holes let it set up for 1 hr. and file smooth and re drill. You can buy square tube aluminium @ Princess Auto to replace the wood inside the door.
Old 11-20-2007, 10:02 PM   #4
A familiar problem. Here's a good posting for you to look at:
1972 Boler Door
boler
Rotten subfloor KarinP Problem Solving | Owners Helping Owners 27 05-17-2009 11:04 AM
Rotten wood strips in my Beachcomber Kris St. Jean Problem Solving | Owners Helping Owners 0 04-13-2009 10:32 PM
How do you know if your tires are rotten? Shelley Care and Feeding of Molded Fiberglass Trailers 13 05-11-2008 03:47 PM
Rotten Wood Donna D. General Chat 13 08-16-2006 04:26 PM
Rotten Egg Smell Legacy Posts Problem Solving | Owners Helping Owners 13 07-08-2003 10:12 AM
» Trailer Showcase
Buttercup
Ian G.
Luna
Karl Be
